How To Root And Flash Clockwork Recovery All At Once-
Download the CWR AIO from the All Things Root section (The Forum you are in) You can find direct links to it in the All Things Root Guide that is stickied at the top of this forum.
Thanks to PlayfulGod and mtmichaelson they have made it very simple and easy to root and flash Clockwork Recovery all in one shot. Here's the How to step by step:
1- Download CWR onto your computer
2- After downloaded, right click and select "Extract" and extract the file.
3- Once extracted, on your phone go to Settings>Applications>Development and check the box next to "USB Debugging"
4- Then plug your phone into your computer and pull down the status bar and press the "USB Connected" notification and select "Internet Mode" and hit OK
5- Open the CWR file you extracted. Once you are in the file, double click "cwm_windows_install.bat" if you are using Windows or if you have Linux double click "cwm_linux_install.sh"
Now a black window will pop up and a bunch of stuff will run. Just let it do its thing and your phone will reboot and you will be not only be rooted but will have CWR flashed to your phone.
To reboot the easiest way download Quick Boot (Reboot) free off the Android Market. Open the app and select "Reboot into Recovery"
How To Make A Backup After Rebooting Into Recovery-
Once you flashed the CWR All in One Root and Recovery you want to make a back up BEFORE you do anything else. To make a back up in recovery:
1- Once you have used Quick Reboot to boot into recovery and are in CWR, using your volume keys to scroll and your power button to select, scroll down to "Back up and Restore" and select it.
2- Select "back up" with your power button
3- CWR will proceed to make a back up of your current ROM. It takes a couple minutes, but once its done select "Reboot System Now" and your phone will reboot
To restore,a back up follow the same steps but instead of selecting "back up" after selecting "Back Up and Restore" select "restore" then select a back up to restore.
How To Install A Custom Kernel-
Download a kernel of your choice from the All Things Root section (The Forum you are in) You can find direct links to each of them in the All Things Root Guide that is stickied at the top of this forum.
1- Once downloaded, its recommended to download it from your computer and place it on your phone, put it on the root of your internal or external sd card. Root meaning not in a folder.
2- Reboot into recovery using Quick Reboot.
3- Then scroll down to "Install Zip From Sd", if you put the kernel on your external SD card select "choose zip from SD". If you put it on your internal scroll down and select 'choose zip from internal". Then after you selected one of those depended on where you put the kernel, scroll down and select the kernel and then Select "Yes".
Let it run and do its thing and once it says its done, select "reboot system now" and enjoy
To overclock download SetCPU, CPUMaster, Android Overclock or an alike app.
How to Flash A Custom ROM-
Download a ROM of your choice from the All Things Root section (The Forum you are in) You can find direct links to each of them in the All Things Root Guide that is stickied at the top of this forum.
1- Once downloaded, its recommended to download it from your computer and place it on your phone, put it on the root of your internal or external sd cards. Root meaning not in a folder.
3- Using your volume keys to scroll and your power key to select, scroll down tand select "Wipe data/Factory Reset" then scroll to "Yes" and select.
4- Scroll down and select "Wipe Cache Partition" and then select "Yes"
5- Scroll down and select "Advanced" and select "Wipe Dalvik Cache" and then select "Yes" then scroll down and select "Go Back"
6- Sroll down and select "mounts and storage" then scroll down and select ONLY these 3 listed, "format data" and then select "Yes", then scroll down and select "format cache" and then select "Yes", then scroll down and select "format system" and then select "Yes". Then scroll down to and select "Go Back"
7- Then scroll down to "Install Zip From Sd", if you put the ROM on your external SD card select "choose zip from SD". If you put it on your internal scroll down and select 'choose zip from internal". Then after you selected one of those depended on where you put the ROM, scroll down and select the ROM and then Select "Yes".
