Are you having an issue? Sprint's policy towards rooted phones has changed.How do i restore the phone back to stock, No root no signs of root or anything, i need to take it into sprint
I'm personally not the owner of the phone, Someone contacted me asking to unroot it, So im doing what they wish i've just never worked with sprint phones and dont really want to brick itAre you having an issue? Sprint's policy towards rooted phones has changed.
I wouldnt worry about it myself.
However, there is an unrooting guide...I/someone will find it and link it to you.![]()
Gotcha, I am a little unfamiliar with unrooting but I do know that it would be helpful to know how it was rooted to begin with and also the information listed in the bootloader screen.I'm personally not the owner of the phone, Someone contacted me asking to unroot it, So im doing what they wish i've just never worked with sprint phones and dont really want to brick it
Gotcha, I am a little unfamiliar with unrooting but I do know that it would be helpful to know how it was rooted to begin with and also the information listed in the bootloader screen.![]()
As far as I know, It's only got CWM on it and a flashed rom of some sort. Would a system restore of the phone not work for the evo?
Okay so can i get that root to the unrooting guide?Like a factory reset? That will not unroot it. It will wipe apps and data from phone only. The rom and recovery will still be intact.
Go to post # 2 at the bottom of post #2 of this guideOkay so can i get that root to the unrooting guide?
Do you know how it was rooted?
Can you get into bootloader screen and read what is there?
Temporarily disable antivirus...Not yet, Can you do me a huge favor, My norton is detecting fastboot.exe download url as a virus, can you reupload that somewhere for me?
Edit: The entire website is being blocked. I need the downloads re uploaded some where
What website is blocked.?
I'm sorry but I dont know where else to get those files, I haven't the need to unroot...
Edit: just saw your edit.....nice then!!
Gosh, Evo has a pretty complicated process to unroot, Esteem is pretty nice in the fact that it has script's for both install's and uninstalls
It does look complicated and I have seen/heard of people having issues but I do not know. Then again, when I first rooted, it looked complicated. Now after rooting 3 Evo's, it's a snap!
Good luck!!
I know if you have issues, just post back or start a new thread.
Ocnbrz know's alot about those kind of issues....![]()
okay i got problems, when trying the cat /sdcard/flash image it cant find the "folder"
We really need to know what the bootloader screen says, the unroot method is determined by it.Go to post # 2 at the bottom of post #2 of this guide
The difference is your esteem is just installing super user into /system/app folder, the HTC has to unlock the bootloader.Gosh, Evo has a pretty complicated process to unroot, Esteem is pretty nice in the fact that it has script's for both install's and uninstalls
Again it may be best to know what the bootloader says before trying to reinvent the wheel.okay i got problems, when trying the cat /sdcard/flash image it cant find the "folder"
i guess i should have read the rest of the thread. sorry goes to the op. i should have been more aware of this.
