Root netflix problem
SMALBA
So I found another problem that might or might not be just me. I can't stream Netflix on this rom. I can open the app regularly but nothing plays. Also I tried uninstalling Netflix and finding it in the app market but it is nowhere to be found??
its not a problem with the rooted rom.. it is also a known issue with the update..
as well as notification blinking, is no longer there.. kinda sux.. but.. oh well..
as mentioned netflix has not made their app compatible with 2.3
there may be a work around on xda but I don't subscribe to netflix so that is the best I can give ya, look on xda or wait for netflix to fix the app ..or you could switch back to a 2.2 rom but what fun is that?
yep sure is. kings gb rom is cm7 based. i believe that it should work. i'm not on that rom any more but i have no doubt that netflix will run on kings gb rom.
