Root New Optimus V, trouble rooting
Scrambles
Member
Hello all,
I just got a 2nd Optimus V for the wife a week ago and I can't seem to root it. (I had no issues with my phone, it's currently running Backside ROM) I've run gingerbreak on the new phone a few times (always reboots after only a minute or so), but whenever I run Romtools I get the "$" telling me that the phone is not rooted. Also, I run the "flash Clockworkmod recovery" from RomManager and it does not update recovery - it's still the stock recovery screen. I musta missed something....any ideas?
:confused: :confused:
Hello all,
Stop. Go no further until you have read this. In fact, it's parent thread should really be your first stop.
I noticed you didn't mention anything about updating superuser or installing Busybox on your wife's phone. The recovery in ROM Manager will mess up phones with OS version 2.2.2, read this http://androidforums.com/optimus-v-all-things-root/419080-truth-about-rom-manager.html
The easiest way to tell if your rooted is to download a terminal emulator and type in: su.
If you get a # your rooted.
ROMTools typically will fool most people.
Superuser is installed (not sure what you mean by "updated"), but I could not get Busybox to install - I keep getting an error, something like "environment error", or some such thing.
So I take it that it's not a change to the phone or the software on it - I just messed up somewhere....I'll start over! Looks like the main problem might be relying on RomManager....I'll let you know how it turns out.
Yes. There's only one thats supported for use on your wife's phone. VM670NH_recovery.img
You did read the provided links in my post, right? The first thing you need to do is update superuser and the su binary (the newest version of Busybox was designed for su binary v3.0, this is why you can't seem to install Busybox). Then install Busybox. Without these two, trying to install the proper flash_image, which is required to install the proper recovery, will be neigh on impossible.
Go to market and search superuser. Select update.
The su binary will take a while to update(it does this on it's own). Make sure you have auto update box checked on the superuser app. This can be done by going to "my apps" section in market and selecting the app.
When that's done let us known and we'll move to the recovery and backup portion.
OK, I finally got home to look at this issue. I updated Superuser and SU Binary. I re-ran Gingerbreak, and checked the root with terminal emulator and got a "#".
Then I tried to install Busybox 1.19.3, and I'm still getting the "Problem with Core Utilities" error.
:confused:
You might try downloading the JRummy16 version of Busybox installer. Select the version that just below the 1.19.3 version. Until you find one that will install. Don't go below 1.18.2
Android system error box says "Problem with core utilities" (I tried 3 versions, down to 1.18.4)
Busybox error dialog box says:
Busybox Installer
There seems to be a problem with some of the utilities needed to install Busybox.
Sadly, I cannot fix this problem and this installer probably will not work.
You can try to install Busybox regardless, but it will probably fail. In order to fix this problem you will probably need to reflash your ROM.
I mighta done a boo boo now I think of it - yesterday I was a bit too eager and I did a factory reset from within in the stock recovery screen. I didn't think anything of it because it went right back to where it was - stock. Phone is working normally, I just cant get Busybox to install.
Busybox Installer
oops! Ok I'll need to research this one. I'll get back to you tomorrow if someone doesn't figure it out first.
Can you verify you have root access still? I've seen root mysteriously "go away " before. Do you have Terminal Emulator?
Just checked it, it's still showing "#"
I think checking the permission of su is in order as well.
As best as I can tell, Superuser and Busybox both have superuser access. Superuser log shows that Busybox is being granted permission. Is this what you mean?
BTW, Busybox installer was updated last night to ver. 6.7. It now has Ver. 1.19.3 of Busybox on it. I tried installing it, and it was still not successful. BUT, there are more instructions on what the requirements are, quote:
1) A fully rooted device (important)
2) A fully nand unlocked device (important)
3) A ROM that supports upgrading Busybox (important)
4) At least 1600kb free in your chosen installation path (important)
The only 2 things that I'm not sure about are #'s 2&3. What is "nand unlocked"? Is it possible that the stock ROM I'm using is interfering somehow? Remember it was restored at one point, after I did a wipe data/factory reset....
That might be it. Sounds like my wife's Intercept. I've never really tried getting past that, she's happy with it as is. It's stock, rooted.
With ES file explorer go to the /system/bin folder. Scroll down to su and make sure it's permissions are set to rwsr-sr-x
If you need help setting up ES just let me know.
Okay, I'm having the same problem as this OP with a new Optimus V revision (2.2.2) this morning. I can't install BusyBox through BusyBox 6.7 nor Busybox Installer 2.0. I've used Gingerbreak 1.2, which reported a successful root. I do receive # after typing su into Terminal Emulator. I have not installed ROM Manager. After reading this thread, I made sure that I updated Superuser (3.0.7) and su (3.0.3). I used ASTRO File Manager (3.0.247.std) and found that the permissions for su (press and hold su, then select Details) within /system/bin report as -r- .
If someone could provide instructions on how to change su's permissions to rwsr-sr-x, it would be appreciated.
Very good advice, but I'd like to add something. When you open ES the first time, go into it's settings, down to root settings then check both boxes.
Hey brotherswing. Now that I'm thinking about it I think I'm guilty of walking over the top of you here. Sorry. I'll just try to add any missing links or info when needed.
I don't use ES, but I know that you can set it up in the settings menu to allow the OP and kunawai(if he downloads ES) to change the permissions once a file is longpressed.
Okay, I've somewhat figured out how to set permissions with ES, but nothing I toggle gives me the s switch (set user or group ID on execution). Is there any means through Terminal to set the permissions of su?
Now that I've messed with the permissions, BusyBox 6.7 gives an error of, "BusyBox Installer was not allowed root access!" I also can't get the # in Terminal, "Permission denied."
Should I resort to restoring the phone or will what I've been messing with in system still be floating around, even after a restore?
No problem, Andy. I like ES because it let's me browse network shares, so I have a tendency to favor it.
Kunawai, you can fix your nerfed permissions from the terminal. Here is a guide on the command you'll need. Restoring ought to fix it, but might be a heavy handed approach to the problem.
