Root [NEW ROMs] GingerElite v2 & PrimeHD 9.0 for X8
gabeyong
Hi,
UPDATE: There are 2 custom ROMs that are equally good at the moment for STOCK KERNEL.
Rather than start another thread, I thought I'd post both of them here... you be the judge which is better.
Still waiting for a good version of ICS 4.0+ to be ported to the Xperia X8...
DISCLAIMER: Please use the info below at your own risk with no warranty of any kind.
GINGERELITE V2
GINGERELITE V2 Features:
* Stable and Fast
* Xperia S look
* Latest Xperia boot animation
* Some Xperia Apps & Icons
* Launcher with Xperia S dock
* Xperia S Ringtones & Audios
* Beats Audio
* Bravia Hack
* Multi-Touch for both Cypress and Synaptic
* Stable and fast
* And a lot of Xperia S stuff
PrimeHD 9.0
PrimeHD Features:
Built from CM Sources
Absolutely Clean
Great performance with 2D/3D
Better graphics rendering
SDCard optimizations: Normal speed upto ~12MB/s
Zip-Aligned for better RAM at boot
Deodexed
updater-scripts tweaks
build.prop tweaks
Edited framewok-res for better battery icons
Optimized PNGs
Also works on nAa kernel
Stock 2.3 Launcher
ICS Transitions
3MP Camera(Sample Photo)
Google Play
Awesome battery life
Beautiful Gallery based on QuickPic*
PrimeDX Settings: GingerDX Settings for PrimeHD with some optimizations, credits doixanh
Requirements:
* Rooted Xperia X8
* ClockworkMod Recovery*
* Baseband 015
* Sony Ericsson Stock Kernel
If you are stuck in a boot loop it's because you have got an old baseband xxx006
Download FlashTool and flash Baseband 015
OR follow the guide below:
[Guide] Using FlashTool to Root and Update Baseband 015 for X8
(A) Make a backup of whatever ROM you are using
1. Restart Xperia X8
2. Multiple click back button when SE logo appears
3. Go to Backup / Restore <click><backup>
4. When backup is complete <reboot> X8
(B) Installation of CUSTOM ROM:
1a. Download GingerElite V2 ROM OR GingerElite V2 ROM
1b. Download PrimeHD 6.0
1c. Download PrimeHD 9.0 and Stock Addons (required for PrimeHD v9.0)
2. Copy ROM to sdcard
3. Reboot to ClockworkMod Recovery*
4a. Wipe data/Factory Reset
4b. Wipe cache partition
5. Install custom zip (and for PrimeHD also install <stock addons>)
6. Reboot
NOTE*:
For those who do not have ClockworkMod Recovery
a) download ClockworkMod Recovery<-- here
b) flash the ClockworkMod Recovery zip file using xRecovery
c) reboot into ClockworkMod Recovery
Other Files You May Require:
Ice Cream Sandwich Lock Screen
Ice Cream Sandwich Wallpapers
Ice Cream Sandwich Live Wallpaper
Root Explorer
Astro File Explorer
Credits:
Like the Custom ROM... Please hit the THANKS button over @ XDA
GingerElite v2 by Xperia Fan
PrimeHD 6.0 by HAKA
cheers :)
gabe
Reference Link:
GINGER ELITE XDA Developers Forum for the Screen Shots
PrimeHD 6.0 XDA Developers Forum for the Screenshots
after installing gingerelite Rom im unable to use xRecovery n clockworkmod. please help how to use these options in x8.
Hi,
to access xRecovery menu
power down your X8
reboot and multiple press the <back> button
to access CWM menu
power down your x8
reboot and multiple press <volume up> or <volume down> button
cheers :)
gabe
i want to know about ginger elite v2..it says that have a multitouch for synatic and cypress..it is correct multitouch i means, real multitouch?
Hi,
The Xperia X8 screen is a single touch screen.
So there is no real multi-touch for this phone, all are fakes.
But you have to consider the level of integration with the software.
Most multi-touch are at the system level and some have multi-touch at selected software level.
cheers :)
gabe
i installed primeHD6 after i did that i can't access xrecovery or clockworkmod when i press back button or volume up stock at sony Ericsson white
I tried this ROM but the problem is the lack of a pre-installed File Explorer. You need to download from Google Play first (I did not have internet access during that time so I was forced to use GingerFast instead)
Hi,
Thanks for the feedback.
I have added 2 file explorers for those who don't have internet access.
cheers :)
gabe
i really want to upgrade my phone into any of the available ROMs out there.
but i have some problems.
"unlock bootloader"
do i really need to do this?
i am following the videos of technewsweekly on youtube,
i really want to do those stuffs but the unlock bootloader thing is stopping me.
can someone enlighten me bout this thing?
thanks!
"unlock bootloader"
thanks!
Hi,
You have to unlock bootloader if you are flashing custom kernels.
Some custom roms are developed to run with custom roms.
All my guides are written for custom roms with STOCK Kernel.
You don't have to unlock bootloader.
Once you unlock bootloader there is no reverting back and you void the warranty on your phone.
So for owners of Xperia X8 who are still under warranty (don't unlock bootloader) you can try a custom rom and revert back the original SE Android Eclair 2.1.1 using PC Companion and warranty will cover any defects.
cheers :)
gabe
Hi gabeyong! Thanks for the great rom.
I've installed it few hours ago and i found that wifi doesnt work. (802.1x EAP with username and password @ my college). Plus, 3G connection is not that good as before. The rest are all fine. Looking forward to your next fix and future amazing roms. :)
Hi guys,
Yes, PrimeHD 8.0 has some bugs.
I was told that a newer version is coming out that will resolve some of the bugs first week of June. So I will update when the new version comes out.
I am still waiting for ICS 4.0+ to be ready. It is in beta 1 stage of development.
cheers :)
gabe
Hi guys,
cheers :)
gabe
3G connection is not work in gingerelitev2
Hi gabe... what does "Sony Ericsson Stock Kernel" means? if im using the gingerxperia v3 does it means that I can use this ROM already by using the xRecovery?
Hi,
Stock Kernel means you have not unlock bootloader and flashed a custom kernel (e.g. nAa or Alfs Kernel).
cheers :)
gabe
hi gabe thnx dat u suggested me to use GingerDXv22 for my Sony Ericsson x8(shakira) its gud, But Der r some bugs in it like file transfer via Bluetooth s not possible . Battery gets drained soon etc . Can u suggest me very good custom ROM which works fine wit all aspects ,fast etc . thnx
