Root NexTheme 10% Circle Battery Mod
Just to make sure im doing it right while in clockwork:
i go to mounts and storage
mount system (unmount system is displayed as first option)
i then go back to main menu (without making a selection)
install zip
choose zip from sd
then select file from download list
Am I missing something?
Get into clockworkmod, Install nextheme again over the top of what you've got, reboot, bootstrap reboot into clockwork again, then install the battery mod and reboot.
Have you tried that?
I'll give it a shot
IT WORKED!!!!!! I'm so happy, thank you very much for all of your help and hard work.
Any chance I could get the white or blue style, but in lime green?
It worked after re-installing the initial Nex Theme and then applying the clock MOD.zip
I guess i should not try and do things like this from in bed, half asleep, at 3am because i was downloading the wring zip in the first place haha
If you're on Revolution, you can get the green version (the link to the revo version is in the OP).
If you want green on Nextheme, go to the UOT generator (see OP), generate your icons and replace the files via 7zip.
I'm on Nextheme, that may be a little more than I can take on rite now. I was more curious if there was a link to a zip thats already made.
No I haven't made one already. Actually, the decompiling and recompiling is the hard part. You can replace (1:1) replace the images in the framework-res.apk.
I'm at work so I can't do it now though.
Ok sounds good. So are you going to make a green one then? Thanks again for all of your help!
Thanks again!
anyone had any luck apply metmorph icons or ninjamorph icons over this? Getting bootloops trying to add the 3dblue signal icons. Just curious :)
