viksince1993
:thumbup:
Do you see anything on your screen (i.e., is the custom recovery menu present)?
Also, does "adb devices" report your device's serial number? (you don't have to post that number here, though...).
yes, the custom recovery menu is present on the screen.
edit: adb devices shows an id with numbers and letters
the entire screen of the phone says:
- reboot system now
- install zip
-wipe data/factory reset
-backup and restore
-mounts and storage
-advanced
clockwork mod recovery v6.0.0.4.7
E: can't mount /cache/recovery/command
e: can't mount /cache/recovery/log
e: can't open /cache/recovery/log
e: can't mount /cache/recovery/last_log
E: can't mount /cache/recovery/last_install
e: can't open /cache/recovery/last_install
I need to step aside for a few, just going to leave this here for reference for SA and myself for future use. Vic, pay not attention to this for the time being.
Code:e2fsck -n /dev/block/mmcblk0p[B]xx[/B]
ty ibt
Ok I won't even look at it
Edit:
Scary, I was asking for help with the red light earlier But what happened was my battery ran out, I'm going to charge it and try:
adb devices and adb shell again after 1 hour or charging
