The problem is that I wont be having so much money for the next nexus.Also the problem with the reboots has been fixed with fw 2.3.4 I thing
2.3.4 didn't really fix it for me even when i am not tweaking things. My fiancee still gets reboots occasionally as well and she is on 2.3.4.
I was on v2.3.3 out of the box and never experienced a random reboot. I'm on v2.3.4 now and it's just as stable as a rock like before. If you experience reboots, it's probably hardware related, perhaps poor heatsinking for the CPU/chipset?2.3.4 didn't really fix it for me even when i am not tweaking things. My fiancee still gets reboots occasionally as well and she is on 2.3.4.
I heard that nexus is using google maps and stuff like that.Does this mean that I have to have access to internet or is there agps.
so it doesnt require access to the internet with google maps cause it is already having the data on it.
Even with older versions of Maps/Navigation data is not needed if you never veer off the initial routing. Data was only needed for re-routing info. With the more recent versions, some of the routing info is cached on the phone so data may not be needed for minor deviations from the initial route plan. But for large deviations or changes to the destination, a data connection of some kind (3G or wifi) is still required.I'm not sure how effective the GPS will be without data at least at some point during the trip.
What is the difference between the sprint version and tmobile version.My previous phone had problems with signal strength and I don't wanna have a phone with bad signal strength.Is the signal strength good?
