Root not reciving texts
cammykool
Android Expert
since late last night i am not reciving texts unless i use the market app LTE onn/off to chang signal type to CDMA only then i get them... do i need to jump back to my stock backup and use the activate app?
Its a Evdo_A + CDMA. What cammy was talking about doing was switching to just CDMA only. You can also switch to Evdo_A only or go back to both.
Evdo_A is 1x mode
CDMA is 2G-3G
It depends on what's strongest where your at, at that time.
the showing options are the ones that work all others are GSM related
by default our phones are set to CDMA auto (PRL)
