Root not sending texts, randomly
togish1
okay, so about a week ago my evo started NOT sending a couple texts...it just does the circle thing saying its sending and gets stuck...i thought it was from the rom, so i put a new rom onto it, and stilll the same thing....any suggestions?
Since your Rooted you should really post these in the All things Root Section. You will get more responses.
What sms are you using? Try changing to another one like GoSMS
Try wiping cache/dalvik cache and see if that helps.
