So I have very little of the android apps installed on my Ally thanks to Velocity. I wanted to move a couple big apps over so they weren't taking up as much space, Quickoffice and Scan2PDF.
I'm not sure where to find the installed apps though first. I've looked under /data with Astro and it says "(Directory is empty)." I need to find the names of the files so I can move them.
Second, I don't know the command off the top of my head to move the files. I'm sure I can look it up though, I'm simply being lazy.
Any help is appreciated, thank you!
