Depends on your definition of thin.
I bought this case a while back. Wasn't as thin as my current case, but definitely covered sides, top, and bottom:
SUNSKY - Frosted TPU Case with Detachable Plastic Frame & Holder for Samsung Galaxy Note III / N9000 (Transparent)
I didn't like the overall feel of the case, but might give it another try at some point. For the price, it was worth a shot and definitely the thinnest case I've seen that incorporates a kickstand.
I just picked this up, also, just for those long days where I know I'm going to be taking lots of pictures and won't be near a charger (e.g. at a sporting event, or amusement park...this type of case saved me when I had the Note 2).
4200mAh Battery Charger Power Bank Case w Stand for Samsung Galaxy Note 3 N9000 | eBay
There are a bunch of different versions of this, but I elected for this one because of the access it gives you to the S-pen. All the other options block the S-pen, but this one has an attachment that connects to the s-pen and allows you to remove it, whenever you need it.
Not interested in portfolio type case that opens on a hinge.
These cases offerNo portrait view with kickstand only landscape. Portrait and Landscape view are make it or break it criteria for me.
Have we found a case yet that is thin, protects top and bottom chrome as well as sides and back, and MOST IMPORTANTLY has a kickstand that works well in BOTH PORTRAIT AND LANDSCAPE VIEW WITH KICKSTAND? (I'm not using caps to "yell", just to emphasize importance) Thanks!
