My Samsung Infuse resets the volume to a very low volume, I would like to know why it does this, I raise the volume on NOTIFICATION VOLUME several times a day.
Actually it does seem to be semi-normal. I know 3 people with the infuse and they all have the same thing happen........ test this out.
Turn notification volume all the way up
Call *DATA# (AT&T)
Check notification volume.
It ALWAYS drops back down to about 25%
I have no idea why this happens but it does seem to be consistant
mine is unchanged. sounds like another good reason to root if you ask me!!!
I rooted my Infuse, and although you are supposed to be able to remove some of the preinstalled applications, You can't. It just won't let you. You can do a few things that you normally couldn't do. The volume issue still remains there even rooted. At least that has been my experience with it. If someone knows how to keep the volume up on the notification volume. Please let us know. I haven't been able as of yet to get that to stay up and it is very aggravating.
