SlasherVRGR
Is anyone working on one? If no.. why not? I'm almost positive we could get these things up to 1.1 or higher with a good kernel.
samsung source code for the kernel wont compile in a bootable state.Is anyone working on one? If no.. why not? I'm almost positive we could get these things up to 1.1 or higher with a good kernel.
as such you dont wnat your phone running at 800mhz while the screen is off.... youd kill a lot of battery like that
who needs setcpu now ;P
Thanks for the insightful information, I take it though that setting Max to say 1000000 wouldn't run it at 1ghz? Also I've never written any android code but I did VB and C# in high school I may do some research and attempt to mod my own kernel.. I have nearly unlimited free time as I'm laid off until may or April![]()
try the admire or the replenish![]()
and read that its all botched up and what have you... here's another interesting question that will probably get me flamed.. but why can't we decompile the kernel from the boot.img file..? There has got to be some way to do it..? That would make this easy mode
I just came to ask about the source and were I would download itand read that its all botched up and what have you... here's another interesting question that will probably get me flamed.. but why can't we decompile the kernel from the boot.img file..? There has got to be some way to do it..? That would make this easy mode
the kernel is in 2 parts, the zimage, which is where the overclocking and several other things are handled and then the ramdiskI didn't mean any offense by asking why it wasn't there. I just mean if he was able to make a kernel how come no one else can get a working one together..? Again, I'm not trying to put anyone down, I'm just curious.
Edit: I hate how small the keys are on the stock gb keyboard![]()
earlier you had asked about frequencies etc oh there is no offense. im just clearing out some infoearlier you had asked about frequencies etc
new optimus explained it all really imagine if you iwll we have a zip file, in the zip file are a bunch of config files and a exe. those config files can do some fairly cool things but in order to edit the game and change the really good stuff... you need to be able to make the exe :/
With that being said the Linux kernel the official one not android is comeing to are phones if u make a kernel u have to build it on the device try building it on the prevail and see if it works
I understand this part. Two days ago I found and used a tutorial on how to decompile the boot.img file. I got 3 files boot.img-ramdisk, boot.img-ramdisk.gz, and boot.img-kernel.the kernel is in 2 parts, the zimage, which is where the overclocking and several other things are handled and then the ramdisk
which is where modules, for ext4 specifically and the rc.init are at.
Problem there is the source is bigger than the phone's memory.
Not on ur SD card u don't put a kernel slice on ur PC's internel memory to buld it I cut my finger at work yesterday I had.to have 5 stochastic and I'm on some strong stuff other I would try my methods as I stated b4 I've bult custom kernels.all.the time.
Then found and used a tut on how to decompile the ramdisk using the console in slitaz and found the system, sys, folders and etc.
Anyway my point was why can't we decompile the zimage.. the real kernel part. I may have to kidnap someone from Samsung and demand a better source![]()
what?
you cant just take the linux kernel and stuff it on your phone
What u can do is put it on the SD card build it from there not stuffing it in the phone internel
Yea u can you can build a kernel for anything anymore instead of trying the original kernel hybrid with the Unix kernel maybe the reason why we don't have some scripts is because you need both android is a Linux just a forked kernel I know for sure that u can do anything u set your skills to
what you are talking about is booting a kernel of fteh sd card that alone would requires ENORMOUS amounts of time just to even get that much going. let alone then taking generic linux and making it fit and work on android, then making it run on the prevail is a whole nother elephant to tackle :/
dual boot is entirly possible... just not sure if its worth teh giant hassle so that people can boot a rom off their sdcard (considering there isnt a whiole lot of difference between stock/cm7 in terms of looks) :/
