Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
@darkwarrior92 No it's not working fine. Mine was not corrupted. New SD card fresh out of the box. Version from 12-17 working fine and no pain with settings to adoptable storage with the same SD card. Official 12-18 giving this problem with adoptable storage. Did fresh install to test.
It did worked for me, but not as I expected, I mean, the program @darkwarrior92 gave didn't fixed the problem, so what I did is that I did a new partition for my SD with TWRP changing the EXT to 128 and SWAP to 32. That fixed the problem, but during the process I had the error of "sd-ext partition not found" or something like that. But it's working properly now.
@vm03 Please just fix FM Radio volume control and also camera video recording, everything else is fine, adopted storage working fine...
If you can't get it to work, use this https://www.sdcard.org/downloads/formatter_4/index.html to format your sd card with your pc, and it will work fine... This software also helped me to fix corrupted sd card...
first i set sd card as portable then i ejected and connect to pc with card reader.. i format with full (overwrite) type and format size adjustment is on.. after that i put my sd to my phone.. notification appear and i select set up then choose use as internal,, and it format my sd card again.. after done it ask to move data now or later,, i choose now and it says not enough storage space again,,, please gimme full tutorial and more explain
So with this rom it will set ext. SD as the internal memory because I heard it will still only alow you 4gb memory placed on SD card,don't get me wrong it's still better than 2gb but a lot of devolopers say LG has trouble reading certain SD cards?or is that just rumors?
I have a LG L70 D320 I would love to give more storage space too.
They can say, but the SD card that was working with 12-17 version is not working with version 12-18 official.
@vm03 Is it just me or cm13 is throttled down to 1.094 Ghz by default? Our SD400 is capable of 1.19 Ghz and cm12.1 is on 1.19 Ghz too.
What a great job you've done @vm03 congratulations!
One question, in the last build (19-12) is running the storage adoptable?
Edit:
I installed the 19 to 12 and working properly build the storage adoptable: D Thanks @vm03
Note: Although the camera does not work in my D320f8, message: Can not connect to the camera, please fix
Hello everybody
Update last official CM13 (12/19/2015) done on my D325 ... no major problems.
Adapted storage SD card works perfectly.
BSOD adjusted using suitable drivers ADB
As against a small bug (if there is one) : Volume (Ringer, call, alarm etc ...) reduces itself sometimes.
Is it a bug or a setting that I have missed?
My LG L70 D325, with ROM CM13. While downloading file or pic
ture, browser always force close, before downloading file finish. Can you help me to fix it? Befor install cm13, I use partition table tool.
Thanks for developer, the ROM very smooth and faster..
[/url][/IMG]
Hi
every thing works fine except that when i connect my d320 to charger it says slow charging and when i try offline charging the screen stays black and doesn't show any of the progress (nothing!) BTW i am not sure if offline charging works or not(cause i cant see the progress, but i will let you know as soon as i tried to charge it from a low %)
P.S: some says that it is LGE battery pach that is causing this problem(only for some devices), so any clue???
