mahdizakizadeh
For me it doesn't connect to server :|Does anyone else have problem with downloading speed from Cyanogenmod site? When i'm downloading new build, it's only around 100kb/s speed....
does the home button work for you?What did happen to the fonts?
Edit: Problem solved.
فیلتر شده سایتش. فیلتر شکن بزن اوکی میشهFor me it doesn't connect to server :|
Just flash the new zip, nothing else is neededHey guys,im using this rom for 2 days now, seems very nice and there's not much bugs. One dumb question here : how do i update nightly builds without losing apps data etc? what should i wipe in recovery before and after flashing new nightly zips? Thanx
What i did is flash + wipe dalvik and cache, seems to work fine.Just flash the new zip, nothing else is needed
To solve this problem, you have to do is format it for use as a portable storage medium, from configuring the device SD cardHi, I have noticed that when u use SD as internal it can no longer be recognised in TWRP. I am guessing due to encrypting it while formatting. So is there any way to solve it?
This rom already have root!Hey, i cant get foldermount app to work on this rom, it requies SueperSU which constantly fails to update binaries here, any help?
I understand that, but there is alot of apps out there that requies SuperSU ONLY. So i cant get foldermount to work anyhow.This rom already have root!
Thank you for the understandable explanation,but it was my error as well turns out i was wrong about my phones model type it turn out to be a lg l70 d321,so im not sure this program is right for it as well.ty anyways.They can say, but the SD card that was working with 12-17 version is not working with version 12-18 official.
thanks,, but its not hard root. is there any way to get hard root for cm13 marshmallow rom?Set Root in developer menu?
Wifi bug? I don't use wifi just mobile data![]()
Thank
Did you set adoptable storage in CM 13?Supersu works, but im stil getting error on foldermount because it cant write i to ext sd![]()
Nope...That happens when you connect to the wifi neighbor
Check foldermount.app permissions in CM 13 Settings/Apps "Can write to SD Card"?No, i didnt want to. Im using my sd as standard removable storage.
