Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Check foldermount.app permissions in CM 13 Settings/Apps "Can write to SD Card"?
@mikkel nf, flash with adb sideload in TWRP. Or reset adoptable storage to internal storage, and put supersu on SD to flash with TWRP. Again, TWRP can't read SD when set to adoptable. That's why TWRP can not find flashable zip.
I'm so late to the party, so late, but good job! Never thought it would get an 'official status' very proud!
Nice job @vm03!
I tried adoptable storage with my 16gb sdcard, and it's work fully. I tested it to copy and install large files and app. But, when I change my sdcard to my 32gb sdcard, it not work. It say that my card is not compatible with this feature. My question is: is this feature (adoptable storage) can not work with 32gb sdcard? Or my card is broken? But, my 32db sdcard still work at other rom, even ms windows... Anyone know 'bout this?
what build you have installed?
The problem I have ... is that using sideload to flash an update ... my phone is not detected (adb devices). Although it is recognized by Windows.
- By installing drivers: adb-setup-1.4.2 .. it is recognized in windows but the adb shell does not recognize the phone
- By installing drivers LG I signed i have a BSOD
Help
Help
il have problem with drivers ..
my device manager
adb shell
always the same problem:
When I install the drivers LG I have a BSOD
When I install the drivers google + adb ... I did not BSOD but my phone is not recognized in the device manager
Well ... I was able to configure the drivers for my D325
The problem :
- In normal operation .. the phone is detected in the peripherals manager and is recognized in adb :
- In recovery mode (TWRP to use sideload) .. it is not recognized and the command does not work :
Until then Windows recognizes the phone ... even when I enter the recovery he always recognizes .. but just when I selects (in the TWRP menu) ADVANCED -> sideload .. at that time the peripheral manager windows no longer detects my phone
Ok so, there is 50% fix on Windows, but is there any solution for OSX because I use it more than Windows... ?? And I use adb a lot, but MTP is also important... And now, I'm using my whole 32GB SD Card as internal storage, so is it possible to access the files on it via card reader?? I'm not sure which filesystem is android using for SD cards???
