Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Quick question, Can I make two partitions on my one sdcard then use one for my music and the other for adoptable storage? I'd love to be able to do that any idea. Thanks again
I was cleaning and forgot I had this phone put away as a back up. Man it feels weird using a smaller phone, I digress. I'm forgot cm13 was out for this device. I'll install then report back later.
Ok, so I must say I like cm13, my only problems were the browser kept crashing but i just installed boat browser.
when I try to download a photo via OG Mods instagram+ I get this message
tried using a sdcard app and I got this message
I'm also getting
net::err_file_exists
'E:Error executing updater binary in zip '/sdcard/cm-13.0-20151220-NIGHTLY-w5.zip'
What should I do?
EDIT2: I just rebooted and it's fixed, but I can't enter recovery with adb, adb doesn't reconginze my cellphone anymore and my home button doesn't work. Why?
Hey, great work! Everything works fine, except the buttons: Home Button is recognized by the phone but only marks something on the display, menu button works as home button. Im a complete noob in cm, this is my first install. I think that I - somehow, during install - lost the original aboot.bin file. I´d appreciate a little help here.
Hi, I have noticed that when u use SD as internal it can no longer be recognised in TWRP. I am guessing due to encrypting it while formatting. So is there any way to solve it?
Another thing
****, can't edit the comment. Deleite that. What i want to say is that now trying to flash the today update (12-21) nothing from muy SD Card appear, and the infernal storage is just used for apps and cache (i though that just the external SD could be in this position, but apparently no). Just my external SD can hace vídeos, images and apps right now, but in TWRP doesnt appear nothing, just LOST.DIR
Hello everybody
I wanted to backup (after installing the nightly 19/12 and my applications) using TWRP 2.8.7.0 ... but it takes a long time and does not perform the backup.
Is it to my SD card (adapted storage with CM13) and therefore EXT4 TWRP can not back it ????
If so ... it is necessary that I put an SD card performs with FAT32 backup ???
Another thing: I downloaded the nightly 20/12 with computer .. and I copied to the SD card (adapted always) ... but the update does not occur. Is this the same cause (TWRP does not recognize the SD card) ???
Guys,
If you have set adoptable storage. TWRP isn't going to see and read the SD Card and find where you have put the download of CM 13. Disk is fully encrypted after setting adoptable storage. Blame Google.:(
I download nightly's with browser.app and use Nandroid for flashing.
Hope there is going to be a working CWM Recovery for OTA updates soon. TWRP doesn't work with OTA updates at the moment.
Ok thank you.
So I use another SD card for backup or install an update ... right?
Nandroid to flashing ??? I did not understand very well.........
Hey guys,im using this rom for 2 days now, seems very nice and there's not much bugs. One dumb question here : how do i update nightly builds without losing apps data etc? what should i wipe in recovery before and after flashing new nightly zips? Thanx
