One update per day. Really?
Not that I'm not grateful, but data traffic is really expensive in my country. And since change log isn't available I am not sure that if it is necessary to update!
Unofficial is just an old version of this ROM..What's the difference between official and unofficial CM13?
Unofficial is just an old version of this ROM..This one is up-to-date version..
No you don't need to. TWRP works fine. Must have done something wrong.Thanks, I just bricked my phone...
Maybe it's because I installed through TWRP? I'm guessing I HAVE to flash CM's recovery and then install CM13?
see post #2
That's official feature in cm, settings -> display -> DPI/LCD density...That's not a bug, you just need to be careful when changing DPI. You cannot just enter any value you wish.
You need to do repartition.I have a problem when flashing the latest version, when it say patching system image unconditionally, it stuck. I've been waiting it for long time but still no go. But, this problem isn't happen when i try flashing another rom .
I've done that when in cm12.1You need to do repartition.
edit : problem solvedI have a problem when flashing the latest version, when it say patching system image unconditionally, it stuck. I've been waiting it for long time but still no go. But, this problem isn't happen when i try flashing another rom .
CM13 need bigger system partition, you need to do new repartition..I've done that when in cm12.1
CM13 need bigger system partition, you need to do new repartition..![]()
If you never do a repartition, and partitions are on stock size, than you dont need to do anything..How I can do repartition? I haven't done that during all the updates i have installed (The latest i installed was 12-23)
NoRecording camera running last update ??????
Use the side of the camera
