Otelo2
Member
Talk in english, forum ruleslg l70 .. ms323 Tienen Problemas con los Datos del destello Pero Aparece Aparece HH + + y LUEGO Desaparece ...
did not workUse the side of the camera
Yes.So I have decided that adapted storage, for all the good it does, is crap due to the problems it creates. Is there a way to disable internal storage, like cm12? Allowing you to move apps to SD normally.
In my case calls are still droped (in 12-29). It seems like it happend when signal strenght is low, but I'm not sure...
Yeh, I have countered some similar issue.if you were to play music on this rom does the music app crash with and without headphones?
This has been discussed a dozen of times already. L70 doesn't have LTE. LTE you see on stock ROM is faux one, it's actually just H+.Recently flashed over and now the L70 is not able to get 4G/LTE. I'm on MetroPCS and using the MS323 variant, everything else works, the APN is correct as well. I just keep bouncing between 3G and H+. Any ideas what could be wrong?
And music player bug!@vm03 Can you please fix video recording?![]()
always the same problem:
When I install the drivers LG I have a BSOD
When I install the drivers google + adb ... I did not BSOD but my phone is not recognized in the device manager
I don't understand why you're even asking...Is Cyanogen Recovery working?
