Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Can't you enter into factory reset mode manually after the device power off ...?
thanks after factory reset i enter in twrp and update last cm13 now work perfect, but super su still dont work and i will w8 some1 to try update with new twrp and after that i will update thanks again
Super SU works perfect on my device without the actualization of binary, try use it
But first u need to go to developer options and activate super user permissions
Don't know why but instead of sdcard1 I am getting a 9016-4ef8. No visible problems except for that name. Its a class 10 32gb sandisk & nothing done except ROM flashing. Had nameless ROM 6.0 with sdcard1 name.
Would like to clarify my situation since I don't understand what happened
I guess Android rename it when made the format to ext4, dont afraid of it, on mine happened the same
You're telling me my microSD has been reformated and renamed? How and why? My data is still intact. :/
Edit: I couldn't care less what android renamed SD to if it wasn't working as it should. Apps like XinternalSD can't detect SD. Its troublesome. I'll try complete wipe
i have active permission but still the same
What version of SuperSU are you trying to install?
I have version 2.67. And I put from under TWRP.
can you give me download link , becouse i was downloading 2,46 like latest supersu, and other question do i need to uninstall supersu from my device before i put new trough twrp
I'm here to warn L70 d325F8's users not knowing that the camera is working very well and HDR also, despite some white stufs appearing at screen, and I'm grateful to VM and all developers here working Hardly to improve and solve the problems, I Wait around 2 years to use cyanogen cause of rear camera, so happy using it..
Hello dear friends, the ROM works fine with exception of Link2SD , I would like to use Link2SD because this allows me to move everything to the SD and if you use the method that biene with marshmalow as not all applications move a few.
Maybe you need to wait for Link2SD update that will work better with MM.. :)
You can use "Apps2SD: All in One Tool" to move apps to sd, and can also mount folders such as "foldermount" for games with "obb files"
It works for me. I have no music on my phone to try the playback but the app works fine
Great for you, while with me It always prompted with "Screen overlay detected" no matter I switch on or off the screen overlay in app setting, the prompt still poping up
### UPDATE
solved by uninstalling LUX
Now if TWRP is compatible with the storage adoptable yesterday just installed the update and install TWRP 3.0.0.0 05.02, then configure storage, and download the update on the MicroSD (adoptable storage) and reboot and start TWRP, it worked perfectly :D
Ah good work done TWRP with 3.0.0.0, only the only problem esque apliaciones adoptable to move the storage function relatively slow, this does not pass the kitkat, I move sla apliaciones in KitKat and work perfect, you can correct the problems and make some more more fluidity to improve the system, and the volumn, improve the volume, better sound and sound even more and that my stay enabled device 100 :D;):thumbsupdroid:
the speed of the app moved to the adoptable storage depends of the read/write speed of the sd
