jules03
THanks for the link but can you help me in specific what thing to do exactly?
Here you have,THanks for the link but can you help me in specific what thing to do exactly?
OTG does not work for this device, hardware problemCan someone tell me does usb otg flash drive work on cm13
Thank you you help alotHere you have,
http://androidforums.com/index.php?threads/918174/
This is exactly what you need, no pain needed
It works for me, all good here.nightly 14-02-2016 (today), clean install: Patching system image unconditionally... (and not advance)
I'll try to the previous (12-02-2016) clean install and I'll seeIt works for me, all good here.
with TWRP 3.0 and clean install? If your answer is "yes", so maybe it was a corrupt download from mehey here ms323, cm13 14-02-16 working like charm, no problem.![]()
It has been already answered in the bugs thread, you need to reformat your SD card again. That is, reformat it as portable, then as internal again. But when you are copying back the backup, don't copy/paste all, just copy essential folder like music, photos, etc.im used twrp 2.8.7 before, then i upgrade it to 3.0.0 and clean install new cm 13 flawlessly, working perfectly, then somedays after installed, i want to go to reboot recovery to flash supersu pro 2.6.7, and im stuck at twrp logo for a long time, i reboot again then go to reboot recovery and stuck again, any solution plz
i cant use adb on my laptop , my windows crashes. some body knows how to fix lg drivers for windows? im using an lg ms323 and i have twrp 2.8.7
Remove LG Drivers and use Google driver instead,i cant use adb on my laptop , my windows crashes. some body knows how to fix lg drivers for windows? im using an lg ms323 and i have twrp 2.8.7
I did reformat sd and then make it like internal but my comp and file explorers dont see my sd card , before i do this my comp recognized my sd like internal 16 gb now when i connect usb it say 1,5 gbIt has been already answered in the bugs thread, you need to reformat your SD card again. That is, reformat it as portable, then as internal again. But when you are copying back the backup, don't copy/paste all, just copy essential folder like music, photos, etc.
Try to do it one more time, the ehole process. Same happened to me too.I did reformat sd and then make it like internal but my comp and file explorers dont see my sd card , before i do this my comp recognized my sd like internal 16 gb now when i connect usb it say 1,5 gb
