Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
clear cache and data of the apps that are stop working .. and reboot atleast 5 times ..
the problem is I can not move this part , only happens when I install the gapps not moving there, trying to do a wipe but it is the problem , I tried a thousand packages gapps and nothing
The only way to start the rom is without gapps jalp
sorry for my bad english
It happened to me
The way i made it work was flashing the rom clearing everything, data cache, sistem on recovery; then i put the last nightly and i installed the nano apps from gapps proyect.
Everything on TWRP 3.0.0
It happened to me
i'll try whit TWRP 3.0.0 because others and I did, I do the wipe data , cache , Dalvik cache and system , install the rom , I install the gapps and reebot , and gapps stop working, I tried to install all possible gapps
Remove LG Drivers and use Google driver instead,
All work for me (MTP, ADB) on Win 8 and XP
ok, please can you show me how to remove correctly lG drivers? i did it many time and didnt work, and where can i get google drivers? theres a link or something?
EDIT: ive solved it. ty now work great !!!
@vm03
That problem with NFC on D320n is annoying, as it not only doesn't work, it also drains battery :) (it keeps device up for about 40% of the time it would normally sleep, according to BeterBatteryStats). Is there any way I can at least disable NFC (it's marked as disabled in settings, I cannot change its state)? Or better, can you fix it anyhow? Thanks for your time (and for great ROM for L70)
Screenshots are of the Settings (to show what I mean by disabled) and of BBS (it's a bit inaccurate, as it was captured shortly after reboot, NFC normally has ~40%)
Hi guys! I get this ROM in my D325F8. It works fine except for some points:
- SIM card not detected
- Weird smudge on camera
- The "About Phone" section shows D320 not D325
So, help me please:
- SIM: How can I resolve the problem with the sim card? Can I get the specific firmware for this and flash it? Besides, are there any plans to make it work on D325FE?
- Camera: is this a specific bug from my model?
- Wrong model: How can I change this?
I really dont want to go back to the stock ROM, it's really bad :(
So, help me please:
Hi Douglas, looks like U're brazilian too, right?
soooo,
-Sim card is working fine, both of them
-the camera have some stuffs apearing, and we need to wait some solution from developers
-U probably using the wrong aboot.bin
Here my vídeo showing cyanogen 13 on youtube /watch?v=kd1PnUvdid8
Does anyone knows how to update the gapps?
Do i have to uninstall the old gapps( i have some of 02012016 installed)?
If i wipe sistem i will have to reformat the microSD that i have integrated on the cellphone as internal storage?
There's another way without losing the 20gb of data that i have on my microSD?
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and TWRP (20140403 or later) recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Read carefully...
Why don't you simply update them through playstore?
soooo,
Brasileiro sim! kkkk I thought that aboot.bin could be the problem. Do you have any idea idea where I can find the right one? And, how can i change the file easily?
Thank you so sooo much :D
Achei esse post lá vai mostrar passo a passo os comandos para você instalar o correto aboot.bin no L70, bom vai ter um link lá denominado "DUMP" clique nele e escolha a opção D325, não tem o F8 no final mas não se preocupe vai funcionar normalmente.
Necessário: PC e cabo USB.
Caso tenha duvidas lá vai ter também um link de um vídeo tutorial ensinado pelo método (fastboot)
Boa sorte!!
Boa sorte!!
FUNCIONOU!!!! CARA TE AMO NA MORAL HAHAHAHAHAHAHA Vou reinstalar a ROM com a versão mais recente que saiu hoje pq o botão de Home parou de funcionar desde a atualizar do dia 17 aqui :P
I'm having problem with Titanium Backup.
Everytime I backup an app it always interrupted by prompt: "Insufficient Storage bla bla bla.."
My Backup Folder is on SDcard, and it has about 5 GB free space.
I can write to sdcard without problem with other app.
Anyone can help me?
