Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
how to screen mirror to smart tv .. i hav chromecast 2nd gen .. but when i connect to tv become it becomes black and automatically disconnects ..please help ....
Yes, those are known issues, you can check the remaining bugs currently affecting each model on cm13 on another thread.
I suggest you try you try AOSP 5.1.1, the latest build from November, works perfectly for me, been using it as my daily driver for two months now.
OH, BTW
You might want to partition your device to get more internal memory out of it, works wonders, and there's an option for Marshmallow too now, the thread is in the root section too.
thats great, i hate that problem from this phone to use the internal memory as micro sd, thats is the reason for root, im going to follow your advice becasue i cant enter recovery manually, i have to use an app
Edit: How i do about memory?
OK.. now I want to ask you all; what app you use to backup apps?
As TiBU failed in my device running this ROM
Try with...
  • Js backup
  • App Backup & Restore
  • Easy App Toolbox
  • Titanium Backup
  • Carbon- App Sync and Backup.
You can browse these apps on Google Play.;)
Hi guys,
am i the only with this issue on google maps? In a certain zoom i see the map "destroyed".
Thanks
Since I installed CM 13, on my wonderful LG L70 D320N , I expect the sound of the conversation to be more growth. Latest update did not solve this problem!
When I'm in traffic, conversations is very difficult
I'd return to CM12, but occupies more space.
PLEASE......
Just can not solve this problem!?
My friend has problems with his D320N using this Rom.
His softkeys don't work correctly. The home button is not on the right place like all the other Buttons too.
Another Problem is, that he can't get root acces at all. It is enabled in dev Settings, but doesn't work. He installed supersu and it says the binary Needs to be updated, but it Fails to update. Is there any zip to get working root acces?
Thanks very much
Thanks very much
Use the app without update binaries, ignore that advice and install and app that requires root, open and it will show you the notification of permission, that's how it works to me
Using this on my L70 D320 as my daily, and its been really good aside the battery drain and the soft-keys arent setup properly I think, because the menu button is used as the home button and the home button has no use. Awesome rom though keep up the work :)
PLEASE......
i have the same model like you but the sound is great :rolleyes:
sd does not work anything or downloads, loss of facebook accounts. instagram skype, zip a disaster 02/22/2016
