Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Hi Vmo3 you have an AMAZING room
i have a problem in variant F8, the acelerometer dont work, dont rotation landscape and vertical mode
i tried applications that can correct this error, but told me that no exist gyroscope.
i wish you can solve this problem
please answer me!!!!!:):(:(:(
Your backup that you have returned to sd messed it up. Reformat the card again, then just copy back vital folders, like music, pictures, etc.
I've tried to: flash the new twrp 3.0, clean install of the cyano, so make sd an internal storage and migrate the files, so tried to update but another time it stucks on twrp logo.
I don't understand which backup u're talking about. May u explain better?
So, when you want to format SD as internal, you normally backup contents of your SD card, right? 99% of us do that by just copying ALL contents of SD card to PC, and then, after formatting, we just copy those files back (drag-and-drop style). Still sounds pretty easy :) But by doing that we are also copy some files which probably are not meant to be on this "new internal memory" (I think culprit may be somewhere in "android" folder. That's why I suggested copying only vital folders (music, video, etc). That's what worked for me, at least, worth a try. Hope I made myself more clearer.
Ok i got it. I'm the 1% that doesn't make a backup =D
However i've retried to format the sd, make it as internal memory, but this time i've not used the option "migrate the files from internal to sd" and now it works. Is that option necessary?
I wanted to migrate just to free some space from the internal memory...i don't wanna have the limit of app installed. Or when the internal memory will be full the phone just will install the app on the SD directly without limiting me?
You can go app by app, and then move all od those which allow you to do so. That's how I did it.
On a totally unrelated note:
Congrats to Leo on winning an Oscar, it was about friggin' time :)
seems to me a tease by google selling format the sd as internal and all apps can happen when a lie is not all apps can be passed to the sd, I think with the partition linksd2 it is much better
Ok, but now the situation is the following:
If i use the option "migrate data" i can't open twrp, but i can see the sd when i connect the phone to the computer (i see internal and sd all together).
If i do not use the option "migrate data" i can open twrp, but i can't see the sd when i connect the phone to the pc (i see only the internal).
¿how I can configure this button to screenshot?
People, I just wanted to let you know Nova Launcher Prime is only 99 cents in Play Store.
With it, you can have "double tap on homescreen to sleep" gesture. That, combined with "double tap to wake" from ROM's settings, and "double tap on lockscreen to sleep" from Gravitybox xposed module gives you stock-like behavior :) double tap everywhere :D
Anyway, just wanted to share.
@zlaja84 Xposed that version of v77?
Been using this for several years, including when on CM11, CM12 and now CM13. But I just don't mention it.
Nice share anyway. Additional app to make double tap to sleep works on home screen, I'm using locksreen app from PS it's a tiny free app.
