Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Using this on my L70 D320 as my daily, and its been really good aside the battery drain and the soft-keys arent setup properly I think, because the menu button is used as the home button and the home button has no use. Awesome rom though keep up the work :)
That is an installation bug, try changing the recovery for TWPR 3.0.0 then install the rom
is the sd-protected bone to throw and is not the first that destroys me and **** CM13 and internal storage
I have 16 gb sd card and works perfect like internal storage, be4 cm13 i wanted to change my phone but now no chance
Mine was also 16G but the problem comes when some file hangs at shutdown or restart the sd gets corrupted, and as I say it's not the first time it happens in this phone luckily have gone to buy it and I they have other sd
Another member of this community told me that cm13 have destroyed his micro SD....infact i was a bit worried to use mine as internal storage...
Edit: After formatting my internal sd as internal storage, i can't read it with my pc (with the phone linked by usb and MTP), but i see only the internal storage of the phone. Someone solved?
Edit2: i discovered is necessary to "merge" the 2 memory by moving the files from internal memory to SD to start seeing the memory from the PC with mtp.
It's not destroyed. Only formatted to ext4. Can be formatted back from ext4 via external software.
I've tried everything and nothing remains the same, if you know of any program or method
Use 'Eassos PartitionGuru'. Search for a portable version.
It supports: GPT partition table and EXT partitions.
I think, too, that converts from GPT to MBR partition table without losing your partitions.
Try these drivers to mount the EXT partition in "read/write" in Ruindows (RUIM in Portuguese is BAD in English) BADwindows :p:D;)
https://sourceforge.net/projects/ext2fsd/files/Ext2fsd/
http://www.fs-driver.org/download.html
EDITED: ext2ifs says it support only ext2 and ext2fsd says it does not support ext4. But in ext2fsd I set as ext3 and access my EXT4 partitions a good!
I don't use NTFS partitions for my DATA files on Ruindows only for the System.
ext2ifs says it does not support ext4. but I set as ext3 and access my partitions a good!
also it serves , thanks anyway
i have the same model like you but the sound is great :rolleyes:
Hello Stevce!
Sound is conversations, to me at least, is weak, say that compared to CM12.
I do not think my device to have a problem because the CM 12 is very well heard.
Have you tried to talk in crowded places?
Other issues that we have observed:
- Auto rotate, the browser does not work
- Google play stops, when I try to install a beeg application. When going back no more stops!
Otherwise it works perfectly!
Sorry for my English, is made with Google Translate!... :)
I'm on a D325, after installing cyanogenmod and setting up my prepaid 3g according to my carrier settings, it connects to H+ and 3G, but shows an exclamation mark and doesn't load anything.
I've tried rolling back to a lot of different builds and wiping every partition every time, still not working.
Does anyone else have this problem?
Edit: Fixed it, had to register with network, can't believe I reinstalled like 50 roms, lol.
Hello Stevce!
hi bro, well i m using this rom from 15.01.2016 and the sound is great everywhere, in the croud
outside the city i dont have problems with sound , only thing with the sound is when i speak i cant
go up or down on sound + -, but the sound is loud and sometimes i want to go low,
- for browser i use cm browser and auto rotate work great
- google play works great too but when i update apps 2 or more it need more time , maybe is the net,
but when i use one by one apps update works fine
Do we have to clean install?
Quick question, I kept forgetting where is the download zip for the nightlies when you download via cm-updater?
After setting the sd card as internal memory, i can't do the cm update because the twrp stuck on the logo...What do u suggest?
You have try with twrp 3?, i have the same problem with older twrp version, but when i install v3 twrp i had the same problem so i reformat sd card and then make internal again and after that twrp works fine
I've TWRP 2.8. So u think i have to:
-install twrp 3.0
-install a clean cyano 13
-make the sd as internal memory.
Right?
Browser from cm13 have problems, when i browse some website after couple of minutes find error i use cm browser and everything is fine.
Your backup that you have returned to sd messed it up. Reformat the card again, then just copy back vital folders, like music, pictures, etc.
