ID: Lg L70 d325f8.
TWRP 2.8.7.0 2016-01-20.
I've been testing the CM13 Nightly build 2016-02-05, with opengapps nano 2016-02-06, Beta supersu 2.67 since yesterday.
front and rear camera running smoothly, with or without HDR.
There is a problem with the frequency resolution of the screen (refresh rate)... It seems that the image multiplies, overlaps and vibrates sporadically. But just turn off the screen and on again via the power button. I experienced to take a screenshot at the time it happened vibration. I turned off the screen, I called and checked the image. The photo image was normal, with no vibration.
I believe characterizes video driver problem, but do not know how to express this kind of hardware configuration problem on mobile devices. Draw their conclusions.
Dual SIM working perfectly;
The audio capture sensitivity is too low. Must be why the audio recorder, Google Now, and perhaps other apps, do not respond to normal tone of voice. You need to talk too loud!
The speed jump, fluidity, and resources is so great that ensures that no back using the Stock ROM Android 4.4.2 KK.
It is highly recommended migration to the CM13 after 2016-02-05.
Note: with each update it should be noted the release of new versions of Recovery, the Super Su, among other essential for flashing your ROM.
Grateful for the attention!
Para os usuários, de idioma nativo português.
ID: Lg L70 d325f8.
TWRP 2870 2016-01-20.
Venho testando a CM13 Nightly build 2016-02-05, com opengapps nano 2016-02-06, Beta supersu 2.67, desde ontem.
Câmera frontal e traseira funcionando perfeitamente, sem ou com HDR.
Há um problema com a frequência de resolução da tela (refresh rate)... Parece que a imagem se multiplica, se sobrepõe e vibra esporadicamente. Mas basta desligar a tela e ligar novamente, por meio do botão de ligar. Fiz a experiência de tirar um screenshot no momento em que acontecia a vibração. Desliguei a tela, liguei, e conferi, a imagem. A imagem da foto estava normal, sem vibração. Acredito que caracteriza problema driver de video, porém não sei como expressar este tipo de problema de configuração de hardware, em dispositivos móveis. Tirem as suas conclusões.
Dual SIM funcionando perfeitamente;
A sensibilidade de captação de áudio está muito baixa. Deve ser por isso que o Gravador de áudio, o Google Now, e talvez, outros apps, não respondem ao tom de voz normal. Você precisa falar muito alto!
O salto de velocidade, fluidez, e recursos é tão grande que garante que não voltarei a utilizar a Stock ROM Android KK 4.4.2.
É altamente recomendada, a migração para a CM13 após 2016-02-05.
Obs: a cada atualização deve-se observar o lançamento de novas versões da Recovery, do Super Su, entre outros essenciais para flashear sua ROM.
Grato pela atenção!
