Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Shinysidewinder
I am using TWRP 3.0. First thing to do is to, when in twrp, go to the advanced wipe and check all except sd card, after that install latest cm build, after install is complete do a regular wipe and then reboot.
I flashed CM12.1 until 13 becomes more stable, but I had an issue... I was using adoptable storage on CM13 and now after formatting my SD card in CM12.1 it shows it as only 15mb... So I downloaded AParted and there is the rest of the space, empty, I format it and then when trying to create a fat32 partition it says the card was not unmounted correctly... I do not have a card reader, I can't do it on the laptop. Has to be on the phone. Ideas?
Just installed the latest nightly (cm-13.0-20160314-NIGHTLY-w5.zip) on my D325f8 and everything went incredibly smoothly, except for a tiny problem I forgot about. The lowest 130 pixels or so of my touch screen do not work, and neither do my hardware buttons. I used to bypass this annoyance with the adb command "adb shell wm overscan 0,0,0,100" to bump up the screen a little and using Floating Soft Keys + Root.
Now I'm stuck at the welcome screen because the "Next" button is in the forever damned lower right corner. Various easy solutions to this dillema are theoretically available, such as:
- Being able to turn on USB debugging and authorizing my PC, so I could use "adb shell wm overscan 0,0,0,100" and "bump up" the screen a little;
- If the welcome screen rotated as my phone rotated (potrait view), moving the button to a clickable position;
- If I could turn on soft keys, as that would also bump up the button a little, making it clickable.
But ALL my attemps to use one of these solutions failed! I can't turn on usb debugging, no matter what I do. No devices are listed when I try "adb devices". I've tried everything. I even modified the build.prop (adding "qemu.hw.mainkeys=0" to the end of it, to see if I could enable soft keys) using TWRP's file manager, but after I do that the phone simply doesn't boot into cyanogen, the screen goes black and I can't even turn the phone off (or on? it looks like the phone is on, but I can't know) again until I remove the battery. When I boot into TWRP, connect my phone to USB, and try "adb devices", it says "LGD325791bcafa unauthorized" and I can't use any adb command.
Any idea how to fix this mess somehow? Thanks.
By the way, I did not encounter this problem with CM 12.1. When I got to the welcome screen there and inserted the USB cable, a window appeared asking me if I wanted to turn on USB Debugging. I said yes, of course, and then I could fix my screen with the adb comands. Seems strange that the exactly same thing doesn't happen in CM 13. A bug? I would use CM 12.1 happily if the camera worked there but... :'(
Has anyone got issue of dissapearing icons from homescreen after reboot? I mean about apps on addopted storage (sd card). Apps on internal storage are OK. D320n
Yes. For me it happened on every update. I simply opened the music player, waited for it to show my music (which is on my SD obviously) and then rebooted and gave it a minute. Apps came back by themselves.
It's because the OS is reading from Internal memory faster than External, that's a common sense. Apps in SDcard is slower to be read.
You can try this:
- Enable usb debugging, if its not already enabled
- Connect USB cable
- On Developer options tap on Revoke USB debugging authorizations, this will reset the adb recognition on your PC
- Re-connect your USB cable
- Type adb devices on CMD
- turn your phone sceen on, you will be prompted by ADB thingy, tap on allow (or something like that) or you can tick on Always trust this PC
- done
You can try this:
- Connect USB cable
- done
I can't get past the welcome screen, so it's impossible to even access Developer Options or, as a matter of fact, anything at all. The only thing I have access to is (1) Cyanogenmod 13.0's welcome screen and (2) TWRP recovery.
But it doesn't matter, as this isn't an issue anymore. I "solved" it by using a different custom rom, one which has the "next" button at the welcome screen in the center and not in the lower part of the screen. Thanks anyway.
With latest update 15.03 i dont have mobile data network, wifi is ok...so i m going back to 10.03 again :(
I found some bugs on my LG L70 MS323:
- The first one: Camera not working completly good. When I record the video, the sound is very noisy and some pixels do not show correctly.
- The buttons "Home" and "Power Off" take several seconds to show the screen lock.
- When I answer a call, and I separate the mobile from my ear, take several seconds to show the screen.
Please, I need help with these points.
Hello World!
Problems with the latest CM 13. 15/03/2016 for LG L70 D320N.
When I try to stop the alarm, the application stops!
Does you know if we will need need to wipe data for release 1? Or only system/cache/dalvikcache?
Hello all, mine LG D325 is working great after the snapshot flashing. I use adopptable storage and all apps works as a charm (i have a good SD card that's a must!).
The only thing that's not working is the mobile data network, only voice! Can you let me know if you facing the same problem or is something I do wrong.
Also i have detected that some of the videos have a background noise that is a little annoying.... probably to be solved for next update.
Thanks
Hi vm03, you make a great rom, congratulations!!!
i have a cuestion, why the gyroscope dont work?? I have F8 variant, and dont work.
i cant put the landscape mode o vertcal mode automatically with the automatic rotation.
Please answer me :confused::(
