Yes. For me it happened on every update. I simply opened the music player, waited for it to show my music (which is on my SD obviously) and then rebooted and gave it a minute. Apps came back by themselves.Has anyone got issue of dissapearing icons from homescreen after reboot? I mean about apps on addopted storage (sd card). Apps on internal storage are OK. D320n
It's because the OS is reading from Internal memory faster than External, that's a common sense. Apps in SDcard is slower to be read.Has anyone got issue of dissapearing icons from homescreen after reboot? I mean about apps on addopted storage (sd card). Apps on internal storage are OK. D320n
You can try this:But ALL my attemps to use one of these solutions failed! I can't turn on usb debugging, no matter what I do. No devices are listed when I try "adb devices". I've tried everything. I even modified the build.prop (adding "qemu.hw.mainkeys=0" to the end of it, to see if I could enable soft keys) using TWRP's file manager, but after I do that the phone simply doesn't boot into cyanogen, the screen goes black and I can't even turn the phone off (or on? it looks like the phone is on, but I can't know) again until I remove the battery. When I boot into TWRP, connect my phone to USB, and try "adb devices", it says "LGD325791bcafa unauthorized" and I can't use any adb command.
Any idea how to fix this mess somehow? Thanks.
You can try this:
- Enable usb debugging, if its not already enabled
- Connect USB cable
- On Developer options tap on Revoke USB debugging authorizations, this will reset the adb recognition on your PC
- Re-connect your USB cable
- Type adb devices on CMD
- turn your phone sceen on, you will be prompted by ADB thingy, tap on allow (or something like that) or you can tick on Always trust this PC
- done
Update scenario number 3.http://www.cyanogenmod.org/blog/cm-13-0-release-1
looks like we are gonna get a release version today.
Hi vm03, you make a great rom, congratulations!!!
i have a cuestion, why the gyroscope dont work?? I have F8 variant, and dont work.
i cant put the landscape mode o vertcal mode automatically with the automatic rotation.
Please answer me
