Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
I try, and I do not recommend.
Has some error, for example, the application "do not disturb" did not answer; I use "do not disturb" and for this reason I quit this version
I returned to the Nightly!
Hmmm for me works everything with snapshot mobile data and rotation is back , before this file manager force closed now is ok, camera work great, if i find bugs i will write
Does you know if we will need need to wipe data for release 1? Or only system/cache/dalvikcache?
Update scenario 3: CM 13.0 nightly user
Update steps: Stop. Step away from the phone. Do not flash these builds, you are already on a newer codebase (Android 6.0.1_r22). Attempting to flash these release builds will result in crashes due to attempted database downgrades. Don’t do it.
If you want to swap off nightlies and stick to our release channel, you will have to wipe to take these builds.
The "do not disturb" function works for me. The screen rotation returned to work.
Camera works but still those stripes flame type with 'higher brightness,' in the view. These flares are captured in photos and videos.
Ps: Guys, enter their phone models to post new bugs. It helps!
ID: Lg Optimus L70 "D325f8 (w5ds)".
twrp-3.0.0.0-20160206-w5.img
BusyBox-v1.24.1-Stericson.zip (flashable zip)
changelog - cm-13.0-20160316-SNAPSHOT-ZNH0EAO1QF-w5.zip
open_gapps-arm-6.0-pico-20160316.zip
xposed-v80-sdk23-arm.zip framework
BETA-SuperSU-v2.68-20160228150503.zip
[app/mod]ultimate adblock/remover+ collection (greatly! improves the daily life of the battery charge)
MoaAB_ADBlocking_03172016_R4.zip (greatly! improves the daily life of the battery charge)
Zlaja you say do not flash snapshot becouse i allready flash snapshot after nightly had bugs and now everything work fine
The snapshot is not supposed to be dirty flashed, as it says in the quote of zlaja's. This is because it is on a stable version of cm13, (6.0.1 r17), the nightlies are on the latest(6.0.1 r21). that is why you shouldnt dirty flash them. Just full wipe and then flash all will be fine.
Ok thanks i just wipe dalvik cache and install snapshot and for now i dont have problems, and if i want to install again nightly again the same wipe right...?
Technically you can do it, but it's not advisable, you see that even cm team strongly suggest no to do it. I'm glad you had no problems, but if some problems arise, it's probably gonna be because of that :)
cm-13.0-20160317-NIGHTLY-w5.zip - d320n
Mobile data are still out of order for me.
Mobile data work, auto rotation stops working after a few minutes.
Finally took the full plung to cm13, with the snapshot. Its good for now, its basically either that right now or stock ROM. Idk I'd love to know whether or not stock has lollipop yet. And I'm struggling to get back to stock ROM anyhow.
Stock doesn't have lollipop, CM13 has been stable for my daily driver for almost a month now, I'd recommend it, however problems may arise
Hi!.
Anyone have CM 13.0-20160305 archive?
I updated to CM 13.0-20160311 - and now 3G not working.
I want back to CM 13.0-20160305 :(
Bro bojkoio i was on nightly and i had more more bugs so i install snapshot and
i didnt find bug yet my net is back, rotation work....
First I would like to thank the developers. I tested Nightly in my LG-D325f8 for 3 days and almost everything works. For recovery I put my old recovery CMW, since I have no information on how to flash the TWRP 3.0. I tried the Flashify and received pink screen fatal error. Only it hurt my prolonged use, because nothing could go to the Boot Recovery and after update is flashed along the TWRP recovery and the screen was filled with stripes and unreadable without options for retrieving and displaying errors. Also the barcode reader to access the Web Whats Up did not work, it was full of stripes and also could not read the code on the screen of my computer.
One question: Could someone explain pass by step how I can put the TWRP 3.0? When I type dd if = / sdcard / aboot.bin of = / dev / block / mmcblk0p6, has an unknown error. Is there any reliable apk without error pink fatal error screen?
Thank you very much .
Thanks for the answer . I install it right with CWM, but after that, the TWRP does not install in any way for any apk. It seems that after the CMW, loses Root and any apk can access the recovery. The Flashify broke my phone often with pink screen and fatal error, so I went back to the original ROM. I ask how can I install TWRP directly without CWM. I don't believe that in Brazil can only install after the CWM, because there is no reason for it, installation instructions at the beginning of this post do not tell you to install CWM and then TWRP v2.8.6.0 . If you want to install a first, not dependent on the other. Could someone give a hint of direct install TWRP. Thank you very much .
the way there , the f8 Brazil only works challenge form , you say pq already gave error when I try to direct flashing , and I have done this numerous times
