Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Because every time you updated the nightly, SuperSU permissions are lost? Use SuperSU Beta V2.68 How I can fix that?
That's right. Su permissions don't survive updating your phone with a nightly. So every time you do the update, you should also update Su binaries through twrp using full zip package from xda. Don't let SuperSu app update itself since it somehow downloads binaries incompatible with our cm13. Updating within the Su app from an app drawer causes a bootloop after restart.
Ah okay, I do esque update and then return to upload the zip SuperSU and works again.
Hello World!
I currently installed version of March 24, 2016.
Everything is almost perfect on LG L 70 D320N
Autoroute works again. Exceptional
The net moves very well.
But However, the battery does not keep me one day with normal use. That is a problem.
Another problem: connects hard data mobile. 15-25 seconds to connect
When the phone is off and connect it to the charger the charging icon does not appear.
I have not noticed other errors. If problememe will resolve these,
will be perfect.
You don't need to flash gapps every time you update with a nightly. Opengapps package is needed only if you flash cm13 for the first time.
Is it your first clean install of cm13 or your already have cm13 on board and just flashing consecutive nightlies?
I do clean install every time, and install open gapps, because of the "residue" of previous versions.
(WTA)
I try to login Line, but the notification error instanly appear. No loading or process to load the email. How to fix it ?
I know is too early to ask this but, what about androidN/CM14?
We'll have possibilities to recibe that update?
Or Marshmallow i's the limit for our devive?
I remember when there were only few Marshmallow sources for Nexus 5 and many people asking when it's gonna be ported to their phones ;) And the saga continues .. :D
I think the proper answer is "we will see" ;)
Since Android is becoming more and more memory consuming, our 1GB ram might soon not be enough. Although, Vm03 might do his magic again, so you will never know :D
