Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
i have 2 apn one is t-mobile internet and second t-mobile mms , but t-mobile internet is checked, i will go back to snapshot to see the settings of apn
If I were you, I would try setting up both APNs from scratch. Delete those you have now. This helped me a few times. You just need to check your carrier's APN configuration first. Always reboot your phone after setting up new APNs.
ok guys thanks i delete my apns and create new and works fine data mobile, but in the install nightly
i mistake and swipe factory reset in twrp :) , and now play store say unfortunately google play store has stopped,
after that i do wipe data , dalvik cahce and system and install again 28.03 nightly gapps and super su but play store wont open :(
I thought about buying a faster microSD for my D320N some time ago, but resigned pretty fast after reading this https://www.sdcard.org/developers/overview/speed_class/ and this http://forum.xda-developers.com/lg-g3/help/bought-uhs-3-sd-card-g3-overkill-t2999360.
Even on much stronger LG G3 the results were not so impressive, so I thought spending more money just fot the sake of seeing "U3 class" logo, is not a good idea. Unless, you are planning to record 4K movies with L70 :D
Still, I'm not sure if L70 is compatible with SH UHS U3 at all. You might be the first to test it ;)
If you need more space, class 10 microSDHC cards can store up to 32GB. If you need more speed, better to install a specific app in the phones internal memory, since it'll still be faster than SD. :)
Hmm, that's strange. Did you try with a different nightly as well? I would clean install a snapshot version + gapps, and then if gapps are OK, I would update with the latest nightly or 25.03 nightly (I'm currently using it without problems) ;)
What is 39999?
does anyone have problem with Whatsapp? I cant login in the app... stuck on "initializing..."
I think I will continue with my SD UHC I class 10 but just buy you the U3 to see if the application performance is different
With nightly 29.03 everything work great thanks guys you are the best
Hello Stevce80 !
How fast to connect to mobile data, the new version (29 .03)?
If the phone is off and you connected to the charger, charging icon appears you the percentage load?
I want to do a clean install and settle down to a good version!
I suspect as the phone has problems if all we do update constantly... :)
Thank you!
