Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
@robi64
Me too me the same thing happens and what I did was go back to yesterday. If someone could clarify how to solve that I am aware.
Regards
april MOD MOD MOD o_O :(
come on it is april fools ;)
Dev`s April Fool's joke ;)
Better to skip update.
robi64 gets it
if you want a laugh have a look into these poor noobs :) --->http://forum.xda-developers.com/nexus-6p/general/cyanogenmod-april-fools-joke-t3349532
@Mystery_Flasher
Our Snapdragon 200 only supports this eMMC 4.51 storage and SD 3.0 (UHS-I), now my question is: How do I know that same thing but from my SD Card ?, to find out if they are compatible. I have a SanDisk Ultra Sd Card 32Gb HC-I Class 10.
Thank you
You don't have to double your posts to get the answer :cool:
What I meant is that our LG L70 can not handle U3 SD cards. There was a question about it few posts above. Your SD is good enough and should be compatible without problems.
Look at the bottom of this pic. When I unlock my phone it shows short cuts and then you tap the bottom and it pulls the notification tray down. It'll most likely be fixed next update
I have a problem installing multiple applications on the play store, app store closes, like installing google chrome, closes the play store. Fix that problem
I had problems with 02.04 like , in network sign appears this ! and wifi didnt turn on when in range many process turn off
smart lock i m back on 31.03
Tell that to the users that are very heavy f8 want a lot and do nothing , when I bought my phone look model development and ask before I arrived
Yeah, I agree. I'm not criticizing you - I'm far from doing it :) I was just reminding F8 users, that they need to give something to get something back :)
this is not new , take the same since CM11 with the repair of the camera, even with my 320n have wanted to contribute to it, but if they do not move unless I will do
Smartlock doesn't appear when is active
I flashed the 2016-04-04 nightly, but the problem persists :(
Anyone knows if it's fixed with 2016-04-05 ?
