Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
@vm03,
1. Sound Recorder local folder in extend storge not working because permision ??
2. Weather panel not get local on refesh tap, and when i change custom local but i not working.
Thank for read !
Hey guys, after flashing cm 13 on my LG D325 I cannot adjust screen brightness anymore. I wonder if anyone else is facing the issue and has found a solution yet ...?
Hi, I got this problem with some CM12 nightly a long time ago. I managed to fix it by using this app: https://play.google.com/store/apps/details?id=com.vitocassisi.luxlite&hl=pl
As soon as I started to adjust brightness with it, the CM brightness slider was working again. I don't know the cause, though.
How is CM13 for D320f8? Is it preferable to stock? And does the camera not work at all? Or only crashes sometimes? Mainly interested in fotos, not video.
Wow I haven't tried this ROM since February so happy to see the in call voice issues are finally gone, I will now be using this as my daily. Only issue I'm still having is Twitter crashes quite often other then that I everything works great.
Hey does anyone else have input lag on 4/9/2016 to wake up it takes one second and it then has to wake up is it doze? anyway its not that big of a deal anyway.
When I plug in the charger (battery approximately 40%),shows charging time is almost 3h,when reconnect charger shows ~ 1h 30 min.
Did anyone have this problem.
Hi, I've got the same. It's not a bug. You just need to give it some time to settle down after flashing a nightly It will show charging time properly after few minutes. It's connected with battery calibration etc.
on my side Google Maps, randomly FC without notice.
I use Waze now.
I'm running the latest nightly and have no such problem. I just checked Google Maps. But there's something related to dirty flashing nightlies, since I also need to reinstall some apps to make them work, from time to time.
I'm too lazy to do a clean flash, at the moment. Waze is a great alternative though. But, thanks for the info.
I use Here Maps (Nokia Maps) and they served me well so far. Premium service for free :)
Stock ROM d325f8.
but gives error because I have root and even after removing
