Why cm13 is so lag in games with openGL 3.0 is a bad óptimization?
In cm12.1 works pretty good
I would say our L70 is far from being a gaming system
If you see a sudden drop in performance between 12.1 and 13, it's not always related to a device itself. Sometimes the dev of the game introduces minor autoupdates that make the game look better but laggy on older phones.
To make sure cm13 is the cause you would have to launch a particular game on two identical phones at the same time but equipped with a different cm. It's almost impossible since the performance is related to many aspects and user's content.
I know the l70 is not a gaming device but I thought that would work like cm12.1 after some updates , tanks for solve my doubt
I solve the problem of lag, only put the battery in "performance"It's great you still give it a chance, btw I never played games on L70, but its' specs are decent. Game developers should not omit this awesome device
And yes L70 has potential but justo a little c:
I have the adoptable storage and works pretty good and no link2sd dont work on cm13 :cWell yeah,it can run games,at least i tried asphalt 8 on cm12 when foldermount was avalible, but now im out of memory ! does link2sd works on cm13 ? or something like that?
so are all my sd cards when used for internal storage and there no way to fix
already done and I used lowlevel, sd formatter and zilch and is not the first to break me this shit phoneyou have to do is formatted with the same adoptable storage, you'll configuration-storage and micro usb- select the card, and you have to format the microsd as storage for photos, videos, etc.
Well, it worked ami me that, I've gotten the micro sd to the computer with adoptable storage and does not work when you format with the same configuration storage configurations, it works.already done and I used lowlevel, sd formatter and zilch and is not the first to break me this shit phone
With the latest nightly I have random reboots and installation of GApps upon reboot.
Mine too is D320N, and the name of the SDcard is just gibberish numbers and letters, although SDcard is working fine.
Hi!
Anyone checked cm-13.0-20160418-SNAPSHOT-ZNH0EAO2NK-w5.zip ???
How it's works on D325f ?
