Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
There's a way to ask they include again the live display??
Hah, I ask myself the same question. Only CM team knows it. The LiveDisplay is still there, but there's some problem with L70 they cannot solve at the moment, so they've chosen to disable it completely.
Recent cm changes are quite surprising, like forcing the users to install third party weather providers, i.e. Weather Underground. Did you try it ?
They claim it's the only way the users may enjoy an accurate weather forecast. I installed this provider and I don't like to be forced to create some account to get it to work. It's kinda frustrating. I don't use cm stock weather widget after seeing that.
No i use google now launcher that provides the weather on my city on the "now" section
I don't understand why they disable active display also , it was working right a mont ago
What about yr.no weather provider? They are the most accurate weather forecast in the world, and have almost every village on the planet in they database.
I use yr.no provider but with Chronus widget. I really recommend Chronus as a replacement to the stock cLock.
Its' free version already provides weather from 6 sources, but still half o them need an API key like WeatherUnderground. The funny thing is Yahoo is doing well with Chronus, whereas Cm13 complains about it beacause of the frequent changes in api.
Chronus itself is also a weather provider for cm13 but the function is there from yesterday and it doesn't work for me.
As an option, maybe you ppl should try weather timeline from Play store. It's a paid app, but my god, it's gorgeous. It's not even expensive, 0.86$.
I recommend you install each update as a clean install, or just update from cyanogenmod?
I'm not sure what you are trying to recommend. It's well known that dirty flashing consecutive nightlies may cause some problems from time to time. But doing a clean install of every nightly is just..a very time consuming idea :cool:
Cm13 is still under some heavy development, so neither way would save you from bugs.
For those who have not decided.
Chronus VS. Weather Underground.Both working.
Chronus:more beautiful,no need API for Yahoo,Accu Weather,yr.no,more options,more widgets but 24Mb.
Weather Underground:You have to register at Weather Underground and get the API key,modest,one widget 8Mb.
The choice is yours.:)
no meu LG-D325f8, os Chips não são reconhecidos (nem um de cada ou os dois juntos)
a câmera funciona (tem umas manchas que ficam mesmo quando se salva uma foto ou video)...a interface é bem leve e fluida da CM13...
ainda não testei o cartão-SD como memoria interna...
Versão usada- cm-13.0-20160416-NIGHTLY-w5
Hi, this is an English speaking forum, so please use English or Google translate at least :)
[QUOTE = "Mystery_Flasher, post: 7285980, membro: 1918086"] Olá, isto é um fórum falando Inglês, por isso, usar o Inglês ou o Google traduzir, pelo menos, :)[/ QUOTE]
sorry kkk
on my LG-D325f8, the chips are not recognized
works camera (has some stain that are when saving a photo or video) ... the interface is very light and fluid of CM13 ...
still I have not tested the card-SD as internal memory ...
Version usada- cm-13.0-20160416 NIGHTLY-w5
as I put google now in CM13 ?
If you're asking how to install Google now
You have to install Google Now Launcher and Google app (I'll ad screens of the apps)
The weather is on real-time by Weather.com and is integrated on the launcher (so is too fast...)
I add some screens of the interface
if someone wanna try
In Quick settings shows only Farenhajt (°F),although it is set "Use metric".
In widgets is all right, shows Celsius (°C).
It's the same in Chronus and W.Underground.
I add some screens of the interfaceView attachment 104450 View attachment 104451 View attachment 104450 View attachment 104451 if someone wanna try
It is that aundo install the google and now he asked to go change the trebuched by now , and when I go to home screen change , only appears trebuched and I can not put the google now to work
Hello everyone. I would like to know how to fix the quick setting and notifications that do not appear in the top bar in any way. I have a ms323 and I am using cm20160501 nigtly.
+1
very annoying
also on d320n cm20160503
seems to be solved.
did a complete wipe and installed cm13 without anything else ,got notifications and quick settings again.
back to twrp and flashing gapps..and they are still there. :)
and stil f.. up,going back to a earlier release.
