Outlaw71
Android Expert
Ok so I've waited it out before attempting to download the GB leak because when it first came out they said it wasn't rooted and I use like 15 different root apps. So that was a deal breaker.
Then I saw where someone said there would be no 1-click root for this, and that we'd probably have to root it the old fashion way. Well I did that way back when root first hit the DX and that was not a fun day.
So then they said they had a pre-rooted GB out, and that the previous one broke the stock recovery. At that point I thought.... man maybe I should tune back in next week and see if everything is straightened out!!!
But the initial reviews have been so positive I'm dying to try it. So just for the record... so that not everyone (like me) has to read through that entire 5 page thread on how to get it, my questions are...
1. It says to start from a rooted 3.2.340 kernel... right? I'm currently on Liberty 1.5 which says my kernel is 2.6.32.9, so I'm assuming I have to go back to one of my stock ROMs, root it, and then do the SBF..... yes?
2. Do you have to have all of the bloat in place like when doing an official OTA update? Or does it just have to be the 3.2.340 kernel?
3. So far the only way to get it is by SBFing, right? No zip files or anything you can do within the phone. You have to download the files to your computer and plug your phone it via USB... right? Gosh it's been a long time since my phone was plugged into my computer. I wonder if they'll come out with a zip file within the next few weeks. Any guesses?
4. Once I am on the new Gingerbread, I can still flash back to my GummyJAR, Liberty, Apex and all those other ROMs... right? I just have to use the D2 bootstrapper to get to them? Or do I use DX Bootstrapper to get to those ROMs and D2 to get back to the GB ROM? That part is still rather confusing to me. Why do some people say DX Bootstrapper still works for them while others say you have to have D2 Bootstrapper? What is the difference between the two?
Thanks in advance to anyone and everyone who tries to answer any of the above questiones.
