Root Optimus 2.3 Overclock roms
AngryTeddyBear
I'm looking for a simple Android 2.3 rom that allows overclocking. And please provide instructions on how to install it. (This is the first time i rooted my phone) Thanks! :D
JerryScript is right. You would find help faster as well if you went to the all things root section. Lots of good threads with posts that will give you all the info and links to accomplish your task. You might find that if you cruise the threads,that the answer or workaround to a problem you might be experiencing has already been discussed,thus making it unnecessary to post a thread. Plus you will gain valuable extra knowledge that you can use to help another member or yourself(we get freely,we give freely).
