CellBlock420
@Bobzhome I have an issue with the installion. When I download the module injectors and I open the download, there are only two folders Meta Info and System. No zip folder and I can't search for it either. Any advice?
I'm still new to Modding, but in carpentry you measure twice and cut once. It's the same with computers. I paid too much for this phone too screw it up by not being careful.
Hi, I'm kinda new to this stuff..
So I did everything as stated and installed SetCPU, but I'm not sure what to do with it from there. My screen is still messing up so is there something I need to do on setcpu to get it working right? Latest kernel is flashed and everything, just dunno what to do with it.
Please provide a step-wise explanation! Thanks!
Yep, I forgot to change a number in the config...It's not a big deal...It will run fine with a wrong number2.1 is a build number in a kernel config file that Bob just forgot to change when he made his new 2.2 kernel. I sent him a pm about it a week ago but he is probably too busy with real life to fix it right now.
Instruction, pay attention to colors@Bobzhome I have an issue with the installion. When I download the module injectors and I open the download, there are only two folders Meta Info and System. No zip folder and I can't search for it either. Any advice?
[LIST]
[*]Download the [B][COLOR=DarkRed]Boot.img[/COLOR][/B] from the link below and [B][COLOR=DarkRed]extract the folder[/COLOR][/B] to where your backups are located on you sdcard(should be in /clockworkmod/backup).
[*]Download the [B][COLOR=Navy]Module Injector[/COLOR][/B] and [B][COLOR=Navy]copy it [/COLOR][/B][COLOR=Navy][COLOR=Black]to the root of your SD card. Do not extract this zip![/COLOR][/COLOR]
[*]Reboot into recovery
[*]Make a backup
[*][B][COLOR=DarkRed]Select backup and restore > Restore > 2012-05-04-BobZ[/COLOR][/B]
[*][B][COLOR=Navy]Navigate to install zip from sdcard > choose zip from sdcard > BobZhome_SPH-M930BST_Module_Injector_v2.2-signed.zip[/COLOR][/B]
[*]Reboot your device
[*]Once your device reboots normally, download SetCPU from Android Market and set OC according to your choice!
[/LIST]
--------- beginning of /dev/log/system
W/PowerManagerService( 158): Timer 0x3->0x1|0x0
I/PowerManagerService( 158): Ulight 3->1|0
I/PowerManagerService( 158): Light Animator Finished curIntValue=20
--------- beginning of /dev/log/main
I/InputReader( 158): dispatchTouch::touch event's action is 0
I/InputDispatcher( 158): Delivering touch to current input target: action: 0, channel '4074c240 Keyguard (server)'
D/PowerManagerService( 158): reactivateScreenLocksLocked mProxIgnoredBecauseScreenTurnedOff=false
D/PowerManagerService( 158): acquireWakeLock flags=0x1000001a tag=keyguard uid=1000 pid=158 myUID=1000 myPID=158 myTID=196
I/PowerManagerService( 158): Ulight 1->7|0
I/PowerManagerService( 158): Light Animator Finished curIntValue=32
I/LockScreen( 158): ***** onTrigger : UnLock *****
D/PowerManagerService( 158): enableUserActivity true
D/PowerManagerService( 158): releaseWakeLockLocked flags=0x0 tag=keyguard uid=1000 pid=158 myUID=1000 myPID=158 myTID=196
I/PowerManagerService( 158): Ulight 7->3|0
D/Beautiful Widgets( 662): UserPresent from Weather14
D/Beautiful Widgets( 662): Screensaver mode: false
I/InputReader( 158): dispatchTouch::touch event's action is 1
W/InputManagerService( 158): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@408ce0b0
I/InputDispatcher( 158): Delivering touch to current input target: action: 1, channel '4074c240 Keyguard (server)'
I/InputDispatcher( 158): Delivering touch to current input target: action: 0, channel '407a5218 StatusBar (server)'
I/PowerManagerService( 158): Ulight 3->7|0
I/NotificationService( 158): Notification canceled by : mLedNotification = null mScreenOn = true mInCall = false mNotificationPulseEnabled = true
W/AudioSystem( 121): get_audio_policy_service()
V/AudioPolicyManager( 121): releaseOutput() 1
I/AudioService( 158): AudioFocus abandonAudioFocus() from android.media.AudioManager@40774580
I/InputDispatcher( 158): Delivering touch to current input target: action: 1, channel '407a5218 StatusBar (server)'
D/skia ( 228): purging 191K from font cache [26 entries]
I/InputDispatcher( 158): Delivering touch to current input target: action: 0, channel '407c5d78 TrackingView (server)'
I/InputDispatcher( 158): Delivering touch to current input target: action: 1, channel '407c5d78 TrackingView (server)'
W/InputManagerService( 158): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@40744a30
I/InputDispatcher( 158): Delivering touch to current input target: action: 0, channel '408a8488 com.fede.launcher/com.fede.launcher.Launcher (server)'
I/InputDispatcher( 158): Delivering touch to current input target: action: 1, channel '408a8488 com.fede.launcher/com.fede.launcher.Launcher (server)'
I/ActivityManager( 158): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.google.android.apps.maps/com.google.android.maps.MapsActivity bnds=[243,338][317,425] } from pid 245
I/GLThread( 1428): onResume tid=23
I/Main thread( 1428): onResume waiting for !mPaused.
I/GLThread( 1428): mPaused is now false tid=23
I/GLThread( 1428): noticed surfaceView surface acquired tid=23
W/EglHelper( 1428): start() tid=23
W/EglHelper( 1428): createContext com.google.android.gles_jni.EGLContextImpl@408bb390 tid=23
I/Main thread( 1428): onWindowResize waiting for render complete from tid=23
W/GLThread( 1428): egl createSurface
W/EglHelper( 1428): createSurface() tid=23
W/GLThread( 1428): onSurfaceCreated
W/GLThread( 1428): onSurfaceChanged(320, 410)
I/GLThread( 1428): noticing that we want render notification tid=23
I/GLThread( 1428): sending render notification tid=23
D/ViewRoot( 1428): WindowLayout in setView:WM.LayoutParams{(0,0)(320xwrap) gr=#33 ty=1000 fl=#20218 fmt=-2}
E/libsecgps( 158): connectToDaemon: fail in connect() : No such file or directory
E/libsecgps( 158): gps_state_init: failed to connect socket /data/gps/secgpsd.socket
E/GpsLocationProvider( 158): set_position_mode failed in startNavigating()
D/NlpVersionInfo( 1428): com.google.android.location not found
D/NetworkLocationClient( 1428): NONE minProtocolVersion -1 maxProtocolVersion -1 releaseVersion -1
D/NetworkLocationClient( 1428): GMM minProtocolVersion 1 maxProtocolVersion 1 releaseVersion 1105
D/NetworkLocationClient( 1428): binding to Intent { act=com.google.android.location.internal.GMM_NLP }
D/NetworkLocationClient( 1428): onServiceConnected to ComponentInfo{com.google.android.apps.maps/com.google.android.location.internal.server.NetworkLocationService}
I/InputDispatcher( 158): Delivering touch to current input target: action: 0, channel '4092d6e0 com.google.android.apps.maps/com.google.android.maps.MapsActivity (server)'
I/InputDispatcher( 158): Delivering touch to current input target: action: 1, channel '4092d6e0 com.google.android.apps.maps/com.google.android.maps.MapsActivity (server)'
D/ViewRoot( 1428): WindowLayout in setView:WM.LayoutParams{(0,64)(wrapxwrap) gr=#51 ty=2005 fl=#98 fmt=-3 wanim=0x1030004}
D/PowerManagerService( 158): acquireWakeLock flags=0xa tag=KEEP_SCREEN_ON_FLAG uid=1000 pid=158 myUID=1000 myPID=158 myTID=345
D/PowerManagerService( 158): releaseWakeLockLocked flags=0x0 tag=KEEP_SCREEN_ON_FLAG uid=1000 pid=158 myUID=1000 myPID=158 myTID=194
W/PowerManagerService( 158): Timer 0x7->0x3|0x0
D/PowerManagerService( 158): acquireWakeLock flags=0xa tag=KEEP_SCREEN_ON_FLAG uid=1000 pid=158 myUID=1000 myPID=158 myTID=164
D/InputReader( 158): Input event: value=1
D/InputReader( 158): Input event: value=0
I/ActivityManager( 158): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.fede.launcher/.Launcher } from pid 158
I/GLThread( 1428): onPause tid=23
I/Main thread( 1428): onPause waiting for mPaused.
I/GLThread( 1428): mPaused is now true tid=23
I/GLThread( 1428): releasing EGL surface because paused tid=23
W/EglHelper( 1428): destroySurface() tid=23
W/EglHelper( 1428): finish() tid=23
I/GLThread( 1428): releasing EGL context because paused tid=23
I/GLThread( 1428): noticed surfaceView surface lost tid=23
Hello I would like to make my boost mobile transform ultra a wifi hot spot. Model is sph-m930bst. I've tried an abunance of apps and nothings worked. Could someone please enlighten me as to how I can make it work please.
Just to make sure, I can install this kernel on stock right?
Is this 2.2 without the 2.3.6 update? Or is this a wifi and GPS fixed kernal based on the 2.3.6 update that works correctly? I would Like to be able to OC my Ultra. I am stock with CWM right now.
