Thanks for the feedback.... I am very surprised to hear that.
I wanted to comment that I have been using this kernel on my Ultra without the wifi module zip on OP flashed to it and I have been using my Ultra tethered to my Intercept over wifi with no problems. It's using the stock wifi module and it works fine. Did I miss reading something?......it works like this fine for me.
.Updated kernel in OP
Thanks to Chevanlol360, for new source info
Hopefully, Samsung got the touchscreen fixed for your phone.
Source changes can be seen here: https://github.com/BobZhome/Samsung_SPH-M930_kernel/commit/898a20e97fe7daedfcd56425e6dcf9f35cb1a374
4-1-12:
Kernel v2:
- Updated: Source from 2.6.35.7 to 2.6.35.11
- Changed: Scheduler to SIO
- Added: TUN
- Added: CIF
- Added: UBIFS
- Added: LATENCYTOP
I'm following instructions for installing new kernel. cwm says "restore complete" but when I check settings I says kernel 26357 and rom manager still only has noop or cfq as options for I/o scheduler.
just flashedUpdated OP with new Kernel v2.1:
j
- Fix: SIO Scheduler
- Added: Deadline Scheduler
- Boot.img - 1) Added BusyBox 2) Fixed netd 3) Fixed rmt_storage
wifi dont work
Did you try the wifi fix? Judging by the description for the wifi fix I believe it will work for this new kernel too... see op
so I thought I would post in layman's terms.
i keep my phone on 1.4 always..and lows at between 368 and 460 mhz...on interactivex
i usally never go above 1.4 because im not trying to shorten the life of my phone..and if i do go above 1.4 its usally just to test and benchmark..never usally that long
i found that if i go below 368 on the low side..the phone can be a lil laggy after waking up..
Updated OP with Wifi fix
Sorry for the problems, it's not easy to work on multiple projects with a wife and five kids interrupting all the time!
