plugged in set to 1.9/1.3 (high/low) - unplugged set to 1.4/0.2 - screen off 0.4/0.1...
Yes but what numbers do I use???
ok I get ya.. your confused because set cpu gives you a read out in megahertz not gigahertzNo what I'm asking is what numbers can I use to get to 1.3?
Any how, with MrRee???RoM and this kernel I'm getting a score of 3600 with quadrant.... that's up there.
Not at the present timeDoes this kernel support UBIFS?![]()
The wifi fix is not really a fix...it replaces your current wifi module with a new one that works with the new kernel.noob question, and ive waited to see if someone else asked it first. But what exactly does the wifi fix do? Im not exactly a fan of fixing (unless thats to tweak to make better) something that already works. I hate to sound insulting but could someone please possibly explain before I jump?
SoonCONFIG_MTD_UBI=y![]()
Your wifi will not work, if you just upgrade the kernel. The old wifi module does not know how to properly communicate to the new kernel.So if I flashed this kernel, without applying the new module, the wifi would not work? Or would certain things not work? Does it change the ability or lack of ability to tether? Sorry for so many questions.
