Following the manual on SBF now. I think I'll be applying the 2.3.320 SBF.
I'll let everyone know how it goes.
Thanks, although I saw somewhere that going to 340 could break things.
SBF is almost done. Looks to be working. When I have it back up and running on stock firmware I'll do the upgrade to 340 OTA
the 2.3.320 sbf you applied is a leak and will stop an ota from going through ,,,,,like bochigo suggested you should flash the .340 full sbf as it wont break a thingThanks, I should have known that but was a little too gutsy
Soo.. how do I upgrade this over the air? I thought there was an auto upgrade option somewhere >.>
