Is there one .zip at the end of the PC36IMG, and not 2?
Try leaving the .zip on the end.says PC36IMG zip then i rename to PC36IMG
Perhaps it will work then..
wouldn't hurt anyways..
Just make sure no 2 .zips tho.
hmmm...perhaps a bad dwld?didnt work ut went pass the parsing steo back to the boot screen. Guess my phone dont like them or something lol
o.k..then, unless someone else knows wassup here, I would try to install with the Android Flasher...are you familiar with that method?I have 2 one is 16g class 4 and the other is 8g class 6. And neither work
No I am not could you tell me how? thankso.k..then, unless someone else knows wassup here, I would try to install with the Android Flasher...are you familiar with that method?
Sure...download Android Flasher here.No I am not could you tell me how? thanks
