I recently rooted with CM7 and had partitioned my SDcard prior to install and I believe Apps2SD (CM) is already part of this ROM.
Here is how I partitioned:
swap: 32
ext3: 2048
If I set apps to default install to SD card in CM7, does it know to use the ext3 partition?
What about if I move the app to SD card in CM7 (by using Manage Applications) does it also know to use the ext3 partition?
I don't know what the ext3 partition gets mounted as so I'm having a hard time finding it using file manager - how can I verify what is in that ext3 partition?
Thanks
swap: 32
ext3: 2048
Thanks
Like I said never used it. Thanks for the heads up with that though.
