I flashed the AlienDroid Android 4.2.1 ROM successfully this afternoon and after that, when I connect the phone to my PC, there's no response on my PC and I can't see the phone on my PC's "device manager", nor is there any pop up telling me to install new drive. The Debugging option is turned on and the phone says" USB connecting" and when I tap it into "mass storage" format my computer can recognize the SD card.
Just back in this morning, I can use the same cable and USB port to connect my phone to my PC, so the cable or USB should be fine. Then I plug my phone into my roommate's PC and the new drive is loading, after several minutes I can see the phone on the PC. So it means something is wrong with my PC. Tried different cable and different USB port , no avail.
But it doesn't really make sense, this morning my PC can connect to my phone with ICS stock room. Or maybe my PC is not compatible with the new ROM?
My PC: Windows 7 Ultimate X64 SP1
My Phone: HTC EVO V 4G, S-Off, HBOOT 1.5,
Thank you for any response.
