Had my new C811 for 2 days now. This evening I turned on the pedometer and went for a walk. Tried to check my progress 30 minutes later and it wouldn't wake up. Had to pull the battery. Since then I've left the pedometer alone, but it's done the same thing 3 more times. I'm not rooted and the only apps i've installed came from the play store, and they are the same apps i've had on my C711. I see on the verizon forum of others having the same problem, but no explanation or solution. Anyone have any insight?
Thanks
Thanks
