phone shut off help!!!!
wahab123
i was talking on my htc wildfire and the battery was almost on end .. so phone switched off by itself .. when i switched on the phone again .. its showed a screeen that says .. fastboot, vol up, vol down, etc
reboot, reboot bootloader , etcc .. HELP MEE PLEASEEEEEEEEEEEEE
welcome to the forums!!!!!!
that is called the bootloader. just select reboot and you should be fine.
try using your vol keys to highlight the reboot option and use the power key to select it. this works on the htc evo 4g and the htc evo 4g lte so i'm only assuming that it should be the same on the htc wildfire as well.
noo sirr its not the same .. my vol keys and power keys both not working??
now that screeen is not opening
its probably because the phone's battery died. pull the battery out and then put it back in and then charge it. once it is fully charge try turning it back on.
and if you still get the bootloader screen then if you can report back what hboot you have and what your radio is and we can go from there.
Hboot-1.01.0001
radio-3.35.20.10
ok let me see what i can find for you. i will look for a ruu (rom update utility) this a way of reloading the os onto your phone and hopefully will restore it back to it bein functional again.....but give me a moment to hunt it down.
in the mean time i would charge the phone like i mentioned above.
