The front light is blinking while charging????
that is fine, quite normal. if the battery is completely dead it will blink first and then it should charge normally.
is your phone a htc wildfire asia? do you know which wildfire you have?
LOL i think everything is made in tawain these daysi m from pakistan lahore ... and at the back it says made in taiwan??
nopedo i need a memory card in this??
its a heavy file .. it would take some time to download ???
BUZZ PVT SHIP S-ON
HBOOT-1.01.0001
MICROP-0622
TOUCH PANEL-ATMELC03_16ac
RADIO-3.35.20.10
Nov 17 2010 12:08:53
FASTBOOT
<VOL UP> to previous item
<VOL DOWN> to next item
<POWER> to select item
BOOTLOADER
REBOOT
REBOOT BOOTLOADER
POWER DOWN
will it work??
still waiting fot the download to complete?
its not happening
i have downloaded that file as u said
after what should i do tell me again
my phone is not working
no volume keys and no power key working
what to do?
ok i believe that this is what you will need:
RUU_Buzz_Froyo_HTC_WWE_2.22.405.1_Radio_13.55.55.24H_3.35.20.10_release_160191_signed.exe
so this is what you do:
1.download the above
2.connect your phone to the pc via usb
3.run the .exe file(ruu)
i got this from the original thread here:
http://forum.xda-developers.com/showthread.php?t=1275680
i would do this with a fully charged phone.
good luck. keep us posted. as always if you need help or questions then you obviously know what to do![]()
BUZZ PVT SHIP S-ON
HBOOT-1.01.0001
MICROP-0622
RADIO-3.35.20.10
FASTBOOT
BOOTLOADER
REBOOT
REBOOT BOOTLOADER
POWER DOWN
ok perfect then yes the ruu i linked you to should work fine.
weird that the vol and power buttons do not work.
