Root Phone stuck in a boot loop...
I hope I didn't over look this information and started a new thread about it. Whatever. My DX is stuck in a boot loop. I just need some help getting it working again...anyone?
Then you probably need the fire up RSD Lite and flash the FULL. 340 SBF file.
Did you make a backup in clockworkmod before the boot loop occurred?
Yes. As soon as I rooted the phone I went into clockworkmod and did a "stock backup". Also if I have to do RSD lite, how is that done? Could you point me in the right direction?
It will randomly boot up to clockwork every once in a while is there an alternate method? I was installing a rom. I wipe data....oh well i guess.
You've got rooolers guide... that should be all you need, SBF back to stock then restore the clockwork backup you made earlyer.
Well I have to go to class now. I hope I will have some solid stuff when I get back :)
Plug your x in the charger and try to boot up ....it may boot you into clockwork where you can restore a backup .....too bad wiping your data partition did not help it usually works
Need to charge your battery before you do anything else. After it's charged then boot into CWM and flash your backup. Instead of SBFing. Download Maderstock340 zip and place it on your sd card then flash it through CMW. Voila!! back to stock.
I have only gotten back into clockworkmod once in the 52347902384 times I have rebooted my phone so I don't think that is an option. :(
