bnb25 Android Expert Feb 27, 2013 #27 bad SD card, have had it happen to me, try reformatting the card
sammyz LG Whiz Kid Feb 27, 2013 #28 Spdfreak34 said: Isn't there a fix for a bad md5 error? Click to expand... Yes there is, it was posted somewhere in the motion forum...
U Ubercharrge Android Enthusiast Feb 27, 2013 #29 i'll try soon, putting my ~3.5gb files back and forth will take time
howeejr Member Feb 28, 2013 #30 Kerv222 said: I tried sammyz unbrick method. It ends up like this... Click to expand... This happened to me as well, I manually installed the drivers from the LG site, do that and you should be good
